Old 06-07-2017, 11:45 AM   #1
BEECHFRONT
BEECHFRONT's Avatar
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS
9.55 Lower pulley belt size
I have a 9.55 lower pulley with stock upper and lingenfelter relocation bracket.
Belt size on the chart calls for K080685 and I installed it and there is no slack at all on the tensioner, very tight.
Anyone else use this belt?
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
2019 HELLCAT REDEYE WB
69-Z28, LSA SWAP, T56 MAGNUM
71-CHEVELLE SS, 496 STROKER TH400
BEECHFRONT is offline   Reply With Quote
Old 06-07-2017, 04:27 PM   #2
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
I have found the lingenfelter belt chart totally useless when it comes to belt sizes. It was no where close when I did a 9.55 lower. You will just have to figure out which length works. I ended up using a K080702.
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners
Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs
ABADZL1 is offline   Reply With Quote
Old 06-07-2017, 05:07 PM   #3
BEECHFRONT
BEECHFRONT's Avatar
The chart floating around on this site is where I got the belt info K080685 for 9.55 and stock upper
I just found the same chart with the LINGENFELTER name on it and it calls for a different belt K080690 looks like it's 1/2" bigger
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
Old 06-07-2017, 05:31 PM   #4
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
I Ran into this also and found out the chart has been updated.
ZMEnow is offline   Reply With Quote
Old 06-07-2017, 05:52 PM   #5
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
The update is still wrong. For me anyway. The chart should have a disclaimer to say approximate.
