06-11-2022, 01:15 PM | #1 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Starter issues
Just went to my car to fire up the first time this week and got a click from the starter. It’s the original starter with 80k miles on it so assuming that’s the problem. Battery is good and added a booster pack to try and start but had to run out and take daily. And recommend starters to replace it with? Seems like summit has a ton of options.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
06-11-2022, 01:26 PM | #2 |
It don’t come easy.
I’d verify the battery condition and then check the wiring and the solenoid on the starter.
06-11-2022, 01:45 PM | #3 |
Drives: ABM #93 Join Date: Oct 2018
Check your ground cables real close as well.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
06-11-2022, 02:27 PM | #4 |
Will be checking the wiring been reading about that now. The battery is good and I know they are crap on our cars lol.
06-11-2022, 03:05 PM | #5 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
I would be surprised if it's the starter with that low of milage. My starter has 170,000 mil on it and still going strong. Like others have said either battery or ground connections.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
06-11-2022, 04:26 PM | #6 |
376 cubic inches of fun
If it's clicking, that's an indicator of insufficient voltage at the starter.
Check battery connections and starter connections before spending money on a starter. |
06-11-2022, 04:47 PM | #7 |
Tried it a dozen more times and it started and started fine now. I checked and wiggled the power cable under the hood and noticed the bolt is rusted is this normal ?
Also see people do a jumper on that cable to increase voltage what do you do exactly?
06-11-2022, 05:09 PM | #8 |
It don’t come easy.
Rusted connections are never ideal. Remove and clean it up, snug it back up and I’ll bet you’ll be good.
06-11-2022, 07:15 PM | #9 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Dont do the jumper, cleaning the connections will do the same thing. I’ve had the same starter for probably 150k miles.
I think the reason my current one is still going is because there’s a brand new one on the work bench lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-11-2022, 09:31 PM | #10 |
Drives: Camaro 2SS Join Date: Jun 2022
Do a big three for ground cables. Use 4gauge marine grade wire. One from battery to ground, another from bell housing to chassis and then another from engine to chassis.
Also, take out your battery ground wire and scrape up the part that touches the frame to remove the paint. Take the bolt out and you'll see what I mean. The idiots at the factory painted the part that the ground wire touches and it doesn't provide an ideal ground. |
06-12-2022, 05:05 AM | #11 | |
