05-27-2014, 06:21 PM | #1 |
Drives: 2010 Camaro 1SS Join Date: Jun 2010
Car pulls to the right
I have now had my car to the shop 3 times for alignments. The car keeps pulling to the right. The shop is telling me that they need to adjust the caster a little bit more but are unable too. I had all Pfadt stuff on from springs, spay bars, endlinks, rear arms. I recently changed my sway bars to the bmr ZL1 spec and changed my rims and tires because they supected that that could be the issue. (I had 22" rims) Is there a caster, camber plate out there you can get without going to coil overs? Or are they missing something.
05-27-2014, 06:27 PM | #2 |
KaBoom1701
Try a different shop?
Mods:
05-27-2014, 07:47 PM | #3 |
Have you done toe rods. When installing those it would be critical to make sure it is in the same spot on both sides since the bolt could be located anywhere with in those two inches. This is just a guess if u have.
05-28-2014, 07:18 AM | #4 |
Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2013
I know this is common sense.
But it isnt the crown of the road making you think this, right?
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
05-28-2014, 07:56 AM | #5 |
Pedders used to make a caster bolt kit to resolve the factory limitations
http://www.camaro5.com/forums/showth...ghlight=caster. |
05-28-2014, 12:58 PM | #6 |
05-28-2014, 01:09 PM | #7 | |
