Old 12-18-2010, 04:37 AM   #1
Sidewinder
Drives: 2SS/RJT/A6/Received 09/09/09
New GM Oil Spec - dexos 1
GM has introduced a new global oil spec called "dexos 1". It is the only oil to be used in all 2011 model year Chevrolet, Buick, GMC, and Cadillac vehicles and is also recommended for pre-2011 vehicles except diesels.
Does any one know if this is a synthetic oil only? I believe Mobil 1 and Pennzoil Synthetic meet the spec. I will have to ask my dealer which oil brands comply with the spec since GM can void the warranty on 2011 vehicles if you don't service them with oil that meets the new spec. In addition to our 2010 Camaro we just purchased a 2011 Equinox. Would rather use just one oil spec for both vehicles.
Sidewinder is offline   Reply With Quote
Old 12-18-2010, 06:48 AM   #2
jehartley
jehartley's Avatar
Drives: Red LT1 & Silver LS3
There is already a thread about this. Use the search function. Lots of info in it.
To answer your question, yes, it is synthetic only.
jehartley is offline   Reply With Quote
Old 12-18-2010, 08:07 AM   #3
2010victoryredss_ron
Born: August 27, 2009
2010victoryredss_ron's Avatar
Drives: 10CAMARO SS,12CRUZE RS,07 YAM R6
Send a message via MSN to 2010victoryredss_ron
good luck finding it in stores yet...only place that has it, is the dealer so far....
Victory Red 2SS/RS
Vin# A9130145
2010victoryredss_ron is offline   Reply With Quote
Old 12-18-2010, 08:30 AM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
several oils already meet the dexos standard:
http://www.gmdexos.com/licensedbrands.html
Old 12-18-2010, 09:05 AM   #5
jehartley
jehartley's Avatar
Not true. I have found it in stores already. Walmart for one. Pennzoil Platinum and Quaker State UD both show it on the back of their bottles. Have not seen it on Mobil 1 bottles yet, but the old stock is on sale like crazy, so I assume it won't be long.
Old 12-18-2010, 10:11 AM   #6
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
I have had a 2011 Camaro for 6 months, and when I asked the dealer about oil changes, they said they would just use Mobil 1.
Can't imagine this spec is REALLY any better than the GM 4718M spec for the Corvette, which most synthetics now meet.
I am going to continue to use Valvoline Synpower in all my cars, including my Z06 and Camaro. If GM does not guarantee the engine, Valvoline will (for 300,000 miles)
Texhawk is offline   Reply With Quote
Old 12-18-2010, 10:40 AM   #7
Markwrench
Drives: 2011 2SS/RS ord 7-7-10 home8-24-10
AMSOIL has the Dexos seal of approval in multiple grades as the "XL" synthetic. Its all I use
Markwrench is offline   Reply With Quote
Old 12-18-2010, 10:46 AM   #8
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Not true.
Tallboy is offline   Reply With Quote
Old 12-18-2010, 10:51 AM   #9
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Service Information
2011 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2505109
#PI0175: Information for dexos 1 Synthetic Blend Engine Oil Usage for Topping Off or Change, Current Availability and Allowable Temporary Substitutes - (Jul 19, 2010)
Subject:Information for dexos 1™ Synthetic Blend Engine Oil Usage for Topping Off or Change, Current Availability and Allowable Temporary Substitutes
Models:2011 Passenger Cars and Trucks (Excluding All Vehicles Equipped With Duramax™ Diesel Engines)
Attention: General Motors new engine oil specification dexos 1™ replaces both current General Motors specifications GM6094M and GM4718M.
The following information may be helpful when encountering a vehicle with the condition as described in this PI.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2505109&from=sm#ss1-2505109">Condition/Concern
• Owners of model year 2011 vehicles may be concerned about the availability of engine oil meeting the new dexos 1™ engine oil specification. This PI provides the necessary information as to what the vehicle owner or dealer service department should do if they need to add engine oil or change the engine oil in their new vehicle, until the availability of dexos 1™ engine oil becomes widespread.
For additional information refer to dexos 1™ Synthetic Blend Engine Oil Announcement - Customer Care and Aftersales Bulletin CCA10-129 (U.S.) or GMP2010-149 (Canada).
• GM has introduced the dexos 1™ engine oil specification because it offers several advantages over engine oils of previous specifications. These advantages include all of the following:
- A greater level of engine cleanliness.
- Additional wear protection.
- Improved aeration control.
- Improved corrosion protection.
- Increased fuel economy.
- Increased sludge control.
- dexos 1™ is backwards compatible to older vehicles and is a suitable oil for pre-2011 GM vehicles (excluding all vehicles equipped with Duramax™ diesel engines).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2505109&from=sm#ss2-2505109">Recommendation/Instructions
• As the availability of dexos 1™ increases, GM highly recommends that owners switch to dexos 1™ as soon as is practical to conform with GM Powertrain warranty requirements.
• When dexos 1™ oil becomes available dealers should use their inventory of American Petroleum Institute (API) Certified for Gasoline Engines Starburst oils in vehicles that DO NOT require dexos 1™ oil.
• GM's acceptance of the use of substitute engine oils is temporary. The acceptability of non dexos 1™ engine oils will be discontinued when dexos 1™ oil availability is pervasive. GM recommends the following substitute engine oils as outlined per applicable vehicle:
Vehicles With Naturally - Aspirated Engines (Excluding Camaro SS with RPO LS3, Corvette, and CTS-V)
Note: Advise the customer to refer to their Owner Manual for more information.
To maintain proper engine oil level or to change the engine oil, substitute an engine oil identified on the label with the American Petroleum Institute (API) Certified for Gasoline Engines Starburst symbol as shown, with a viscosity grade of SAE 5W-30.
To maintain proper engine oil level or to change the engine oil, substitute an engine oil meeting the GM Standard of: GM4718M, also identified on the label with the American Petroleum Institute (API) Certified for Gasoline Engines Starburst symbol as shown, with a viscosity grade of SAE 5W-30.
Vehicles With Turbocharged (TC) Engines
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2010 General Motors. All rights reserved.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 12-18-2010, 10:52 AM   #10
MS3DALE
MS3DALE's Avatar
Service Information
2011 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2523337
#PI0215: Oil Filler Cap Identification and Changes - (Aug 23, 2010)
Subject:Oil Filler Cap Identification and Changes
Models:2011 Cadillac CTS-V, DTS, Escalade, Escalade ESV, Escalade EXT, STS
2011 Chevrolet Camaro, Corvette
Equipped with Engine VINs E, F, J, P, S, T, W, 4, 6 (RPOs L37, LSA, LAU, LD8, L37, L99, LS3, LS7, LS9)
The following information may be helpful in identifying and avoiding unnecessary parts replacement at the time of Pre-Delivery Inspection (PDI).
Condition/Concern:
Technicians may notice during PDI that the oil filler cap on the 2011 vehicles no longer has the "Mobil 1®" logo printed on the cap.
Previous Design Oil Filler Cap:
Revised 2011 Oil Filler Cap:
Recommendations/Instructions:
Important: DO NOT replace oil filler caps because they no longer display the Mobil 1® logo.
Starting with 2011 vehicle production, GM no longer specifies Mobil 1® as the required oil for the above vehicles. A new oil specification called Dexos I has been created, which a variety of synthetic and synthetic blend motor oils meet.
Note: For additional information on available Dexos 1 oils, please refer to PI0175.
• 2011 vehicles equipped with DOHC V6 engines (RPO LF1 and LLT) are no longer built with Mobil I logo caps. These vehicles should be serviced in accordance with the Dexos I standard.
• SRX models with the DOHC V6 (RPO LAU) engine used the "Mobil 1®" cap from the 2011 start of production to August 1, 2010.
• All Chevrolet Corvette and Camaro models along with the Cadillac DTS, CTS-V and Escalade models will continue to be built with the "Mobil 1®" style cap until November 2010.
Old 12-18-2010, 10:54 AM   #11
MS3DALE
MS3DALE's Avatar
ExxonMobil Remains Lubricants Supplier for General Motors U.S. Dealer Network
Extends 20 Year Relationship in the United States
  • ExxonMobil will continue as the GM supplier for the U.S. GM dealer network for the next five years. <LI class=bwlistitemmarginbottom>ExxonMobil is now licensed to provide dexosTM trademarked products to GM dealers and consumers worldwide.
  • Mobil 1 licensed for dexosTM specifications.
September 10, 2010 01:38 PM Eastern Time
FAIRFAX, Va.-ExxonMobil signed an agreement to continue as the lubricants supplier for the U.S. General Motors’ dealer network for the next five years. In addition, ExxonMobil announced that a number of its key products, including Mobil 1, are now officially dexosTM licensed worldwide.
“We can count on ExxonMobil to support our dealer network and train them on the use of quality lubricants.”
The new dexosTM licensed ExxonMobil products will meet the GM global engine oil specifications and will be designated by displaying dexos1 or dexos2 logos on the product labels. These engine oils are designed to meet the specific requirements of gasoline and diesel engines used in GM vehicles worldwide.
“We’ve been working with GM for a long time, and we look forward to continued growth with this important alliance,” said Ken MacGibbon, sales director strategic global alliances for ExxonMobil Lubricants & Petroleum Specialties Company. “ExxonMobil has been the supplier for the U.S. GM dealer network since 1990, and during the last 20 years, the GM service fill program has become one of the best original engine manufacturer lubricants programs in the industry. With strong efforts between both companies, we have grown sales, including Mobil 1, every year within the GM dealership network.”
“Our track record with ExxonMobil has been very strong, and we select our lubricant supplier based on their quality, reliability and their ability to help us grow our business,” said Jeff Quigley, general director, GM Customer Care and Aftersales. “We can count on ExxonMobil to support our dealer network and train them on the use of quality lubricants.”
ExxonMobil’s dexosTM licensed products will provide consumers with a strong product offer giving GM drivers more options when it comes to their motor oil. Part of the offer will be Mobil 1, the world’s leading synthetic motor oil brand, with Mobil 1 5W-30 for dexos1 and Mobil 1 ESP 0W-40 for dexos2.
As part of the agreement, ExxonMobil will also market General Motors’ new semi-synthetic engine oil, ACDelco dexos1 5W30, to be launched later this year in the U.S. and Canada.
Old 12-18-2010, 10:59 AM   #12
MS3DALE
MS3DALE's Avatar
Pennzoil Platinum® Exceeds New Oil Spec For 2011 GMVehicles
HOUSTON, July 2010—General Motors is introducing dexos1, a new global engine oil specification for gasoline and E85-fueled vehicles, in all 2011 model year Chevrolet, Buick, GMC and Cadillac vehicles. Basically, the company requires that every owner of these vehicles use an oil that is dexos1approved at every oil change. It also encourages owners of pre-2011 GM vehicles (except diesels) to use a dexos1-approved oil as well, as the new specification offers several advantages over previously available motor oils, including improved levels of:
• Engine cleanliness
• Corrosion protection
• Sludge control
• Wear protection
• Aeration control
• Fuel economy
GM says these will result in improved engine life and performance.
Therefore, every owner of the GM vehicles mentioned — new and old — should be pleased to learn that new, next-generation Pennzoil Platinum
® full synthetic motor oil is fully dexos1-approved in the popular SAE 5W-30 viscosity grade.
And they should be even more pleased to learn that new, next-generation Pennzoil Platinum
® actually exceeds dexos1standards, particularly in the area of engine cleansing. Pennzoil Platinum® keeps pistons up to 40% cleaner than the toughest industry standard*. So try new dexos1-approved Pennzoil Platinum® and Feel The Clean.*Based on ILSAC GF-5 and Sequence IIIG piston deposit test using SAE 5W-30.
Not just oil, Pennzoil.®
http://www.pennzoil.com/documents/DexosPressRelease.pdf
Old 12-19-2010, 04:56 PM   #13
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
I didn't read all the replies so I don't know if this was mentioned. The GM Dexos oil is not a full synthetic, it is a synthetic blend. I will just continue using the Pennzoil Platinum in my car.
Oldrocker is offline   Reply With Quote
Old 12-19-2010, 04:57 PM   #14
camaro1
camaro1's Avatar
true dexos is only a synthetic blend,
2011 Dexos oil spec Texhawk Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 09-03-2010 01:27 PM
ON STAR OIL Life % T_MECO Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 04-25-2010 08:55 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
