#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
BeckyD @ James Martin Chevy
Old 07-13-2017, 08:30 PM   #1
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: ZL1
2017 1LE stuck in reverse
Today while backing into a parking spot, I went to put car in neutral and was stuck in gear.
Turned car off and on and let it roll forward and it came out of gear. Went through all gears was fine.
Looking for insight if something I should worry or look into or dismiss as a fluke
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 07-13-2017, 09:52 PM   #2
MySS8U
MySS8U's Avatar
Drives: Black 1SS 1LE
If it ever happens agin scroll threw your gauges and check the Transmission temp. See if its higher than normal.
MySS8U is offline   Reply With Quote
Old 07-13-2017, 09:52 PM   #3
Hard Parker
OMWTFYB
Drives: ZL1
Gotcha
#savethemanuals
Old 07-14-2017, 06:11 PM   #4
HOST1LE_gen6
IG @HOST1LE_gen6
HOST1LE_gen6's Avatar
Drives: 2017 bright yellow 1LE
Here's the video if anyone has an idea or suggestion
https://youtu.be/8T5pJItHhA0
HOST1LE_gen6 is offline   Reply With Quote
Old 07-14-2017, 11:40 PM   #5
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
That video doesn't show a car stuck in reverse.
If the issue is with the reverse camera, it does take time for it to turn off like all cars with reverse cameras -that's a universal technology. She doesn't allow any time for the shifter to stay out of reverse for the camera view to disappear. The beginning of the video shows the display, shifter, and camera in reverse. Then she quickly goes between reverse and neutral. What does this video even show?
MAGAUSA is offline   Reply With Quote
Old 07-14-2017, 11:41 PM   #6
Hard Parker
OMWTFYB
Drives: ZL1
It's my car and I'm a HE...what the video shows is the I'm not able to put the car in neutral...shifter is stuck in the gate
#savethemanuals
Old 07-14-2017, 11:44 PM   #7
MAGAUSA
MAGAUSA's Avatar
Sorry... Nice nails...
Old 07-15-2017, 12:30 AM   #8
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
Lol.
Almost seems like an issue with the reverse lockout that allows you to go into reverse after the car is stopped, but somehow not allowing you to get out of the reverse gate. It looks like you are able to get out of the reverse gear, just not out of the gate.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 07-15-2017, 12:34 AM   #9
Hard Parker
OMWTFYB
Drives: ZL1
^^correct
I eventually get out of gear but while in neutral I have a hard time putting in gear. Once in gear the car is fine. Also, not able to wiggle it in neutral
#savethemanuals
Old 07-15-2017, 10:55 AM   #10
SaphfireSS
Drives: 2017 Camaro 1LE SS
First question do you have skip shift elliminator? If you do take it off. It caused my car to not be able to shift out of neutral several times. I didn't believe it until I took it to the dealer and luckily had a cool service tech that told me he's ran into this several times on the Vette platform. Removed it and it hasn't done it since.
SaphfireSS is offline   Reply With Quote
Old 07-15-2017, 12:40 PM   #11
Hard Parker
OMWTFYB
Drives: ZL1
Car is tuned so SS is turned off
#savethemanuals
Old 07-15-2017, 01:39 PM   #12
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
Still, are you positive that there is no actual skip shift resistor installed? This could cause that by effectively locking into gear (in your case reverse).
Does your 1-4 warning still come On?
If so, does the solenoid stay completely open (no lock, no rough feel going into 2nd)?
When you run it hard, is the 1-2 shift smooth? How about 5-6?
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
