![]() Drives: 2011 Camaro 2SS Join Date: May 2016
Transmission Mount
is anyone running a strengthened Trans Mount that they would recommend, my trans seems to be very loose and thinking the power I'm putting down has worn out the rubber mount.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
The only option I've seen for the trans that isn't factory is the rev shift insert. It's probably not too good to do it without upgrading the engine mounts. There's several options the Prothane, BMR, Detroit Speed. This will get you a bunch of NVH. That will suck in a DD.
I've read that the Z/28 engine and trans mount are stiffer but liveable in a DD. That's my first step. If it's not enough I'll go Prothane and Rev Shift insert. Hope that gives you something to work with... Sent from my P00I using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
#3 | |
#4 | |
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
#6 |
Here's the info I'm going off of. Quoted from a FB 1LE group. So it depends on the year of your car. Now my question is are all 2012 and up engine mounts the same as the Z/28?
"When I bought a new 5th gen manual trans mount for use with the Revshift insert, I found 2 different part numbers for 6.2L (w/o supercharger), but with no clear description of how they differed. I bought both so I could compare. The mounts are identical except the green label mount (see pics for PNs) has harder bushing material and a different mounting bolt material - I know the green label mount comes with the 1LE, and I assume the Z/28. I’m guessing the other one with softer bushing comes with the regular SS. (I didn’t know the 1LE and Z/28 came with stiffer trans mounts than the SS, but it makes sense). Also pictured is the Revshift insert, which is a harder material than the green label trans mount." ![]() ![]() ![]() ![]() Sent from my SM-G935V using Tapatalk
#7 |
So it would help lethalss who has a 2010. But my 13 has the stiffer mount.
#8 | |
I have twice the hp he does and my stock trans mount is doing fine. I just checked it the other day. I am also running Pfadt engine mounts, 1 piece DS, and solid subframe mounts. Lethal2SS, get under your car with a crowbar and see if you can move the trans around and watch your mount to see how it reacts. |
#9 | |
#10 | |
#11 |
Ah! You should have posted that info in your original post! I wasted SOOOOO much precious internet time trying to help.
JK In all seriousness, glad you know what the issue is. I have spent a lot of time chasing something only to find out the real cause wasn't what I thought it was. |
#12 | |
#13 |
Well then I guess get the updated trans mount and consider the insert. I'd still address the engine mounts in your situation.
#14 | |
