07-24-2015, 08:28 AM | #1 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Altering Auto-Trans Shift Points
I use to work for a company that made transmission dyno's. I left shortly after the newer electronic shifted units, we all drive, took over. I have a 2015 2SS RS and I'm not really happy with how fast it gets to 5th and 6th gear. You might be in either gear at 35MPH or less. It just creates an engine lugging sound and feel. I get that it's done for fuel mileage reasons but how efficient is a 6.2L V8 running at 900RPM lugging at 30MPH?
I'm pretty sure shift points can be re-programmed through the ECM and/or via a hand held "tuner" plugged into the tranny data port. I was just wondering if anyone here has done that?
07-24-2015, 08:42 AM | #2 |
Drives: 2012 2SS/RS Auto Convertible Join Date: Jun 2014
My tuner adjusted my shift points when he tuned the car. I'm pretty sure every tuner who tunes an auto adjusts these points.
Sent from my SAMSUNG GALAXY S6 EDGE using Tapatalk Pro |
07-24-2015, 08:46 AM | #3 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Yeah , will have to be done via a tune.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
07-24-2015, 08:58 AM | #4 | |
Drives: 2014 SS/RS Blue Ray Join Date: Mar 2015
2014 1SS/RS L99 Blue Ray Metallic
Patrick G Tune | K&N High Flow | SOLO Axle Back w/ J-Pipes | JEGS X-Pipe Resonator Delete |
07-24-2015, 09:14 AM | #5 |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
You can raise your shift points at any shop that'll dynotune your car. It isn't a big deal, but this is one of the tradeoffs of an automatic transmission. You're never going to have complete control of where your car shifts unless you buy a manual transmission, or run around in paddle shift mode all the time.
07-24-2015, 09:22 AM | #6 |
Drives: "Bette White" '11 2SS/RS LS3 Join Date: Jul 2014
a Manual-Transmission swap will fix that problem for ya ;P
- Bette White - '11 2SS/RS LS3 /w Driver-Mod, Hurst Short Throw, Rx CC+1LE CSS, Hawk HPS Pads, Apex Motorsports SkipShift Elim, Gen5DIY DRL Harness+P13W/11W/4300K Fogs/DRLs; Otherwise stock - Soon to be spoiled
07-24-2015, 09:32 AM | #7 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
It only does that when you are driving it too easy. Put it in sport mode, and put your foot in it. If you drive it more aggressive, the trans will go into more of a performance mode and run the gears out and hold gears at a higher RPM. There are also trans tunes, that you can tune just the Sport side and leave the normal Drive side alone.
07-24-2015, 09:53 AM | #8 |
Drives: 2015 2SS Red Hot Adrenaline Join Date: Apr 2014
Tune and/or control via the paddles.
I got my car JRE tuned recently with the SCT X4 and it shifts so much faster and firmer now. Chirps second without really trying. Love the difference the tune made.
2015 2SS Red Hot Adrenaline |
07-25-2015, 10:40 AM | #9 |
Drives: still coming Join Date: Mar 2015
Either let it reprogram by a tuning shop or if you want to do it yourself, get a Diablo Intune. Having your own handheld tuner (the size of a very small smartphone) alows you to fiddle with the parameters until you're satisfied.
(But please stay away from fiddling with the fuel injection parameters on the Intune unless you do EXACTLY what you're doing!) |
07-25-2015, 11:14 AM | #10 |
I do use the paddles quite a bit. I used to work for Superflow and talked to an old workmate yesterday. He said there's a remote chance these "stacked shifts" could be a valve body problem but more than likely, it's designed that way so GM can report better numbers for their 'gas guzzler' status.
That's the upside to an electronically shifted tranny, (as opposed to the old governor shift) that it can be tuned. He also said any reduced fuel mileage would be negligible. Thanks, folks.
07-25-2015, 12:21 PM | #11 |
aka 'slush box' - you will be much happier once transmission is finely tuned.
07-25-2015, 01:37 PM | #12 |
Yeah, I find it kind of annoying listening to it lug at 900RPM. You can't have yer foot in it all the time! BEAUTIFUL ZL1, Vick415.
07-25-2015, 03:37 PM | #13 |
Sounds like you have AFM issues. Yes, you can tune it out OR you can get a plug-in Range device, run it in Sport Mode, and be happy as a clam.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
07-26-2015, 11:39 PM | #14 |
Yes, more a shake than buck. I'll admit, it's more of a sound than a feel, but still a minor shake. I can't quote the exact gear ratios but 6th gear at 35MPH would seem to want to lug any V8 engine, based on my old school experience with 3 and 4 speed tranny's at low speeds.
