05-18-2018, 08:02 PM | #1 |
Drives: 13' 1LE Join Date: Apr 2012
F14 drag wheels with 26inch drag radial bronze on IOM PICS
Heres my setup, finally together, after a journey for a Spec Mini Twin clutch install!!
You gotta be careful with where the weights are installed; has to be very close towards outside..front 18x8 clears "roller skates". Rear are 17x10 with 315 35 17 Toyo TQ. Front are 235 50 18.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
05-19-2018, 05:33 PM | #2 |
And now with the rear only Pedders 1inch drop!! ������
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 05-19-2018 at 11:37 PM. |
05-21-2018, 05:15 PM | #3 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Looks good, just a lot of wheel well.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
05-21-2018, 05:22 PM | #4 |
Drives: 2010 SS Join Date: Jun 2015
Why 2.5-3" shorter tire than stock??
05-21-2018, 05:28 PM | #5 |
Instagram: Sangstah
Those look tiny on there, maybe get a taller drag tire?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-21-2018, 06:54 PM | #6 |
Drives: 2015 ZL1 Join Date: Apr 2018
Are you going with such a shorter tire for gearing purposes?
2015 ZL1 Coupe - Summit White | Stock (for now) |
05-21-2018, 10:17 PM | #7 |
Yeah, I want my 11s pass and better gearing, the cheap way
The 27 28inch tires are so much pricier, I wanted to give a try with the 26. The real bummer is that only Mickey Thompson makes the 28, and I want to ride on it all summer long on this with better durability. I would have liked Nittos or anything more street oriented...but nothing available in 28". Honestly, it looks better in person, but even then, I really got used to it. But a 28inch tires will look awesome!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 05-22-2018 at 12:04 AM. |
05-22-2018, 06:04 AM | #8 | |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-22-2018, 06:04 AM | #9 |
Btw- looking good my northern neighbor.
05-22-2018, 08:37 AM | #10 |
Thanks man!
Well I wanted to run a real drag pack for WR and better launch...I wanted to run them 17" in the rear! I think Ive lost 10lbs on each corner.
13' 1LE
05-22-2018, 03:42 PM | #11 | |
Makes sense. I know a number of GTO guys who did that as well.
05-23-2018, 10:53 PM | #12 |
Im gonna add that dropping the car 1inch will make the car touch the 17inch while accelerating (keeping in mind I run 26inch tires in the rear). Had to get the lower rear arm heated then hammered to clear the wheels, like half inch.
13' 1LE
