08-26-2018, 07:39 AM | #1 |
How often should I change Mobile 1?
Hi, I have a 2012 Camaro SS with 3900 miles on it. I last changed the oil in July 2016 with 3000 miles and put Mobile 1 in her, the reason being I do not drive the car much and did not want to put in any dyno oil that would accept moisture. My question is in terms of time how often should I change the oil being it is synthetic Mobile 1?
08-26-2018, 08:05 AM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I would recommend changing it once a year regardless of mileage. After a year it gets moisture and contamination... should be changed imo
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
08-26-2018, 08:26 AM | #3 |
Drives: 2010 Camaro Join Date: May 2014
08-29-2018, 05:43 PM | #4 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Yeah, even with synthetic you have to change it once a year regardless of mileage. That's for the warranty. If the warranty is gone, then I don't think two years is really that bad. The moisture thing might bother me though. So, I'd do it every year. Better safe than sorry I guess.
08-29-2018, 06:03 PM | #5 |
Instagram: Sangstah
I use Mobil 1 and change every 5k miles.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
08-30-2018, 05:22 AM | #6 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I agree - At least once a year. You need to drive it! Letting it sit is more harmful than not driving it. Rubber seals and O-rings will harden when they sit for a long time.
09-12-2018, 12:06 PM | #7 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I change my at least one a year or 5k which ever comes first.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
