07-04-2016, 12:12 PM | #1 |
Drives: 2011 2SS RS Black Vert Join Date: Nov 2013
Vibration/Rattle from underneath
I have a 2011 SS Vert and lately when going over bumps I have noticed a rattle/shake from underneath that at times you can feel through the floor pans. It only does it when going over larger bumps in the road but it has gotten more noticeable lately. I thought it may be a broken exhaust hanger but I got under the car yesterday and everything seemed to be tight. Just curious if anyone ever had a similar issue or may know what else to check.
07-04-2016, 01:15 PM | #2 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
With a rubber hammer hit your cats, they can be coming loose from inside. Also hit your mufflers and resonators.
07-04-2016, 01:55 PM | #3 |
When I hit them with the rubber mallet what should I be listening for? Also the car has a flowmaster exhaust so I am not sure the mufflers are causing the rattle as it is under the floorboards but I will check them. When you say coming loose from the inside what do you mean? Coming apart(failing) or just coming loose from the pipes. Thanks
07-04-2016, 03:42 PM | #4 |
Dimitri
The exhaust also has heat shields. Check to make sure they are not hitting anything.
When you hit the cats and mufflers they should sound solid when you hit them. If they don't they need to be replaced. |
07-04-2016, 06:53 PM | #5 | |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
07-04-2016, 09:23 PM | #6 |
Drives: 2014 BRM 1SS/RS Join Date: Sep 2011
Could be the exhaust pipe hitting the tunnel brace. It happens on my Camaro!!
2014 Blue Ray Metallic 1SS/RS A Road Warrior |
07-05-2016, 12:19 AM | #7 |
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300 Join Date: Aug 2012
Exhaust rattling against the heat shield or tunnel brace, loose connections.
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS! |
07-05-2016, 11:33 AM | #8 |
I am assuming the heat shield is above the cats or x pipe. If it is hitting or rubbing is there a fix for it?
07-05-2016, 12:45 PM | #9 |
Banned
Drives: 2012 2SS INFERNO ORANGE Join Date: Apr 2015
Thread Tools | |
