06-11-2019, 03:31 PM | #1 |
Started#gottalovethatblue
Color change halos
Who has them?
What kits/brands did you use? How do you like them? Did you have to open your lenses to install them? Also, for those of you who did them for your fog lights, same questions as above and how do you get into the fog lights if you have to open yours? I've heard you cannot back them like the headlights.
06-11-2019, 08:42 PM | #2 |
Drives: 2013 Camaro SS Join Date: Oct 2016
If you have factory halo's go with Diode Dynamics. If you do not have factory halo's go with Oracle Lighting. Either way you have to open your lenses. This is an intimidating task to think about but it really is VERY easy. When re-sealing them most recommended Silicone but that makes it a two day project. I used the same sealant as GM does to make the headlights in the first place, Butyl Headlight Sealant. You simply put a bead around the assembly and reheat it in the oven to seal your light like the factory does.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 I personally have Diode Dynamics with the bluetooth controller and they work flawlessly. |
06-30-2019, 07:29 PM | #3 |
Drives: '16 2SS Join Date: Apr 2011
You don't need to open the headlights just to swap LEDs. We have our original, RGB kit...
https://www.camaro5.com/forums/showthread.php?t=147129 ...as well as some other choices. Fog/DRL lamps have to be cut open. |
07-02-2019, 03:55 PM | #4 |
I got it and responded back just now.
Thread Tools | |
