02-23-2014, 08:53 PM | #1 |
Drives: 2010 2SS/RS Join Date: Jan 2013
Did the holley intake ...
Switched from the Fast to Holley...
Just a pic thought id share Install wasn't bad at all... Now all I need is a hood ,I'm really hoping the 3" Harwood will clear... |
02-23-2014, 08:58 PM | #2 |
Save lives? Hahahahaha
Drives: An ambulance, a 2ss/rs, x-wing Join Date: Sep 2013
Ehhh just cut a whole in your hood and let it all hang out lol Looks awesome bud.
02-23-2014, 09:02 PM | #3 |
Banned
Drives: ... Join Date: Dec 2013
How much did you have to modify the cowl?
02-23-2014, 09:16 PM | #4 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I want to know the dyno numbers compared to the FAST...
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-23-2014, 09:19 PM | #5 |
02-23-2014, 09:32 PM | #6 |
I worry that this is going to be a tq killer on your car man. You just moved the entire powerband up by about 800 rpms or so. That's fine if you have aggressive gearing and A LOT of converter. But on small cam street rides, its hard to beat a properly worked LS3 Manifold.
Good luck with it bud. |
02-23-2014, 09:45 PM | #7 |
Banned
I wonder if you could use a shorter motor mount for some more cowl clearance. I wouldn't want to lose a wiper or cut the cowl really
02-23-2014, 10:21 PM | #8 |
Drives: camaro turtle Join Date: Nov 2013
Rhino is on the right track. You need a custom cam made for a tunnel ram, and a lot of converter to go fast with it.
This nick no longer in use. Please direct all future pms to 'Dietcoke'
02-23-2014, 10:39 PM | #9 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
I can't wait to see results! I agree it might actually hurt, although I have no idea your car setup. In the olds world edelbrock came out with a victor intake, that thing actually made more power then any intake out above 3k even on a very mild setup. So you never know!
10.91 at 122 H/C stock block N/A
02-23-2014, 11:18 PM | #10 |
Drives: 2013 SS Join Date: May 2013
Looking forward to the results with the new setup Zach!
02-23-2014, 11:24 PM | #11 |
Banned
What tb are you using? What size is the inlet on the Holley?
02-24-2014, 03:05 PM | #12 |
Yea it's getting a bigger cam and nitrous outlet kit along with a nice converter and 3:91s...
102 intake ,oem TB,Nick Williams 102 is on back order... Eventually car will be boosted with a 80e...till then I'll play with it like this ,thx |
02-24-2014, 04:32 PM | #13 |
Drives: Camaro Join Date: Apr 2009
definitely dyno before & after before buying the hood. I often see guys remove that intake after seeing how the power shifts up. :( It is awesome looking though, just needs big rpm.
02-24-2014, 04:32 PM | #14 |
I believe the nick Williams throttle bodies we have in stock
