07-20-2014, 09:26 PM | #1 |
Drives: 02 z28 Join Date: Jul 2014
#7 cylinder melted side of piston
My question is I didn't see any ware in cylinder so I ordered a standard master rebuild kit and started to hone cylinders and test fitted rings when I seen #7 cylinders ring gap is .035 could I just install a set of .010 oversized rings in that cylinder and grind to fit them or will I have other problems
11-09-2014, 03:52 PM | #2 |
Drives: Porsche 964 Join Date: Oct 2014
No you can't just install a .010 over ring.
You will have other problems. You need to have the bore measured. |
