Rick@Livernois
Old 07-24-2011, 09:10 PM   #1
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Service Stabilitrak after LTH Install?
Anyone have any experience with this?
Got the headers installed and took about a 12 mile joy ride with no issues or CEL whatsoever (though I know without tune it's coming).
Day later, took a drive out to eat and as I was pulling in to the parking lot I got the service stabilitrak message (though still drives fine - no limp). After eating, came out, light came back on, though went off about 1/4 the way home and came right back on 30 seconds later. Repeat twice more off on cycles, then stuck on for good it seems; with blinking CEL.
Did a quick search here and it looks like one other guy had this message and attributed the issue to a cracked spark plug during install. I'm not sure this is the same thing cause I think that would have came on during my joy ride.
Thoughts?
2017 Camaro ZL1 M6 - Everything but the sunroof - New Daily Driver! Commuting has never been so fun.
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 07-24-2011, 09:33 PM   #2
Gordo
Gordo's Avatar
Drives: CMG 2SS/RS
Check all your plug wires and plugs,I had the same issuse and didn't have one of my wires on all the way.
Gordo is offline   Reply With Quote
Old 07-24-2011, 09:46 PM   #3
Parapdrapa
Drives: 2010 Camaro
It could be the plugs. But the problem is actually your tune. I am guessing u have an m6? If so you are having a mis while starting to move and it will piss off ur stabilitrack. It happened on my gto after header install. It also happened with my sub par cam tune. I hope this helps, I doubt it's anything tho u won't notice it after ur tune.
Parapdrapa is offline   Reply With Quote
Old 07-24-2011, 09:55 PM   #4
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Have onstar run a diagnostic
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 07-24-2011, 10:37 PM   #5
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
I am having an issue with the stabilitrack too. I had my headers installed more than a month ago and no issues until now. I had the message pop up on my dash and Onstar told me it was a wheel speed sensor in the driver side rear wheel. So I put my stock tune back on and went to the dealer. They replaced the sensor and sent me on my way. Got my car back lasted 1 day before it was back on my dash, I have not yet checked my spark plugs or wires but now its off again and has been for 48 hours
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, JRE tuned
06blownSS is offline   Reply With Quote
Old 07-24-2011, 11:34 PM   #6
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Plug wire.
SUX2BU is offline   Reply With Quote
Old 07-25-2011, 01:29 AM   #7
10camaross
10camaross's Avatar
Drives: 2010 camaro ss/rs 6spd manual
This actually happened to me today i installed new headers and exhaust and it has a mis and the trac light is on
10camaross is offline   Reply With Quote
Old 07-25-2011, 06:17 AM   #8
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Misfire at any cylinder will cause the stabilitrac message to activate.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 07-25-2011, 06:37 AM   #9
Infern0
Bring It
Infern0's Avatar
Thanks for all the feedback guys! I guess the consensus is something to do with the plugs after all. I'll check out all the wires and make sure they're snug. If that doesn't do the trick I'll have to start checking the physical plugs.
Old 07-25-2011, 08:09 AM   #10
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
I dont think its the plugs. Your sig mentions ARH headers which means you probably disconnected the steering shaft shaft while installing the headers? If you did and managed to move the steering shaft or wheel a small amount the car will throw a code.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 07-25-2011, 09:48 AM   #11
Infern0
Bring It
Infern0's Avatar
Yeah you're right, had to disconnect it. When attempting to reconnect after install it wasn't lining up enough so I threw the key in to unlock the steering wheel and get it back aligned.
I understand what you're saying may cause it to throw a code, but would it clear itself and come back on a couple times if that was the case? I'm also thinking it would have come on during my first joy ride right after install too, not just the day after. What do you think? If this is the stabilitrak code I'm seeing, would the code be different that what I'd see if it was a loose plug wire or damaged plug (almost certain it would have to be).
Old 07-25-2011, 09:55 AM   #12
toehead93
Drives: 2014 2SS/1LE
Did you reconnect the alternator? I missed it and got the same message as you.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 07-25-2011, 09:56 AM   #13
Snake Slayer
Do a search a few people have had the same issue with the steering shaft. I don't recall how they resolved the code .. Sorry. Try reaching out to Nick from ARH he is on the board and good luck.
Awaiting 2014 C7
Old 07-25-2011, 10:07 AM   #14
garcmol
garcmol's Avatar
Just throwing this out there, because cut outs set this code and it appeared as "Service Stabilitrak".
Service Stability Message On, Diagnostic Trouble Code (DTC) C0131, C0196, C0290 and/or C0292 Set (Inspect/Replace Yaw Rate Sensor/Lateral Accelerometer and Reprogram Electronic Brake Control Module))
What set it off was resonance from the cutouts. Headers can produce this resonance as well. This resonance throws the yaw sensor into a fit and throws the service stabilitrak message. If you have access to a code reader you could check it out. The car did not get a CEL! Just the stabilitrak message. FWIW
Service Stabilitrak came on after getting new tires shadow09 Wheels and Tires Talk Sponsored by The Tire Rack 70 03-15-2017 10:36 AM
GM dealership customer service and sales HPlover Camaro Price | Ordering | Tracking | Dealers Discussions 15 04-01-2014 11:48 AM
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 01:12 PM
service stabilitrak... adub4185 Suspension / Brakes / Chassis 17 04-19-2010 06:36 PM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 08:31 AM
