11-20-2016, 11:37 AM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2016
Help please? 2010 Camaro SS cammed what oil do I use now
Hey guys I have a 2010 Camaro SS cammed and I was told to change my oil to 20w50 VR1 is that true or what can I use because it says 5w30 on my engine but they said since I'm cammed I need to use the 20w50 VR1 any suggestions?
11-20-2016, 01:51 PM | #2 |
Drives: 2010 ABM RS camaro Join Date: Oct 2015
i use 20w50 race oil in my 1969 camaro high horse power high compression i think it wont hurt to run it all that matters with a after market cam you need a lot of zinc in your oil.i always use royal purple Also 20w50 does not like the cold.
11-20-2016, 02:32 PM | #3 |
Mobil 1. 0W40 as recommended by my tuner.
11-20-2016, 04:05 PM | #4 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
I've been running pennzoil ultra platinum 5w30 since doing my cam and all is fine
11-20-2016, 05:02 PM | #5 |
Drives: 2011 Green SS M6 Join Date: Jun 2015
Royal Purple 10W40 here
11-20-2016, 05:07 PM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
5w30 Mobil 1, no problems here.
High ZDDP isn't necessary for hydraulic roller cams
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
11-20-2016, 05:39 PM | #7 |
Love me some Tacos
Strange seen some people say that is not good. The ones on the life of their cam one. Anyway...
11-20-2016, 11:35 PM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Ran VR1 20w50 in both my GTO's ('04 & '06). They did not explode. I think you'll be fine. My personal opinion is to use dino oil in cammed cars. Of course, I use dino in all my cars. But everyone has their opinions.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
11-20-2016, 11:42 PM | #9 |
DO NOT PUT 20w50 in a LS motor not clearanced for it. you should be running Amsoil ZRod 10w30 or Driven LS30. unless your motor was built and the bearings were clearanced to run 20w50 DO NOT RUN IT.
11-21-2016, 10:23 AM | #10 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
I'm running Amsoil Z-Rod 10w30.
11-21-2016, 04:00 PM | #11 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Which cam? Cam Motion cams don't need to be babied like rest
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
11-22-2016, 07:42 AM | #12 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
Say what?...
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
11-23-2016, 10:28 AM | #13 |
11-23-2016, 10:42 AM | #14 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
I use rotella 5w40 synthetic change every 5k or little less no oil use or leaks car has 92k cammed at 82k tsp 235 239 cam dod vvt delete
