Old 10-08-2017, 02:16 AM   #1
Avoooo
Drives: 2013 agm Zl1
Sputtering and hesitation when moving
Car runs good for the most part except when it gets this annoying sputter and hesitation. It only does this when I’m already moving and start rolling into the throttle and happens in second to 6th gear randomly, not full throttle but at about a quarter to half throttle. It never sputters when I fully punch it only when i slowly get into the throttle and the car will hesitate and sputter until I take my foot off the gas and then it will drive fine. It idles normally from what I can tell and runs very strong when I got WOT. My car has bolt ons, 9.1 lower pulley, arh headers and highflows, rotofab Intake, 850 injectors and a tune. I don’t know what this could be for the life of me and any help would be greatly appreciated. Could it be a dying fuel pump, weak maf? Thanks in advance!
Arh headers, injectors, rotofab cai, lower 9.1 pulley
Avoooo is offline   Reply With Quote
Old 10-08-2017, 10:35 AM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Are you running a BAP? Do you have the ability to run some data logs?
ZMEnow is offline   Reply With Quote
Old 10-09-2017, 12:25 PM   #3
Avoooo
Nope, no BAP as of now but will be camming it in the near future so will be running it forsure. And as for data logging I don’t have any tools to do so and honestly wouldn’t know what I would be looking at regardless lol.
Old 10-09-2017, 12:42 PM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Who tuned it? Take it right back.
Can'tHave2MuchHP is offline   Reply With Quote
Old 10-09-2017, 04:30 PM   #5
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
To much pulley and injectors to at least not be running a BAP...Your probably running out of fuel...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 10-09-2017, 05:57 PM   #6
Can'tHave2MuchHP
Drives: Fast
He's got the same supercharger overdrive as you do. (2.55 = 18%, 9.1" = 18%). A Boost-a-Pump (BAP) is not necessary for 18% on a properly functioning fuel pump. ID850s/ID1050s alone will be fine. Also, running out of fuel would not be what he's describing which is mid throttle loss. Running out of fuel would matter when you're revving it out, 5500+ RPM. Then you'll notice immediate power loss. If you were "running out of fuel" at "1/4 to 1/2 throttle" then you could kiss your engine good bye at WOT.
It's either a sensor, the tune, or your fuel pump taking a dump. I'm not a professional tuner, some members on here are and may have other things to check. Your tuner should definitely be able to handle this, he'll be able to datalog, see codes and more.
Old 10-09-2017, 06:40 PM   #7
ZMEnow
When I was data-logging my ID850's I saw fuel pressure dropping at around 3500 as I set up my Ramp on my BAP. I just don't know how he can maintain 60 plus pounds without a BAP.
Old 10-09-2017, 09:38 PM   #8
Avoooo
The odd thing about it is it doesn’t do it all the time it’s random, on some drives it won’t do it. It’s been doing this for a few months and when I first noticed it I Left it at my mechanic for a couple days and they drove it around and it didn’t do it once. I’m goona call my tuner and see when I can take it up. Thanks for the help my friend.
Old 10-10-2017, 09:43 AM   #9
Can'tHave2MuchHP
Drives: Fast
Every car is different, but I seriously doubt anyone should need a BAP at only 18% over drive. Was your car a 9.1 or 2.5 pulley?
I think that eliminates the possibility of it being a fuel pump if it's being on and off for a few months. A fuel pump may have fluttered around a few times but it likely would have gone within an hour of you first noticing this issue.
A tune could be the issue, but more than likely this is a computer reading a bad sensor or something. I've not yet handled one of these issues yet so my experience ends here. But you definitely need it data logged, so if you can't do that then get it to a tuner who can.
Old 10-10-2017, 10:07 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
Most common is plugs cracked or damage, wires not securely connected or damaged, we see this scenario often.
Only skips when high demand is put on the ignition system.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-10-2017, 10:10 AM   #11
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Ted.
What Ted said!!!
owhite3003 is offline   Reply With Quote
Old 10-10-2017, 10:49 AM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Cracked spark plug...
Dont ask how I know this.
Mods:
Old 10-10-2017, 10:52 AM   #13
Can'tHave2MuchHP
Drives: Fast
Ahhh of course.
Old 10-10-2017, 02:50 PM   #14
Avoooo
Ted.
Thanks Ted,
