07-21-2011, 07:02 PM | #1 |
EOD
Drives: 2015 ZL1 Join Date: Jan 2011
Stock fuel pressure?
Couldn't find this with search.... Can someone tell me the stock fuel pressure at idle on a 2010 L99?
Thanks |
07-21-2011, 07:11 PM | #2 |
Drives: CTSV Join Date: Feb 2011
4 bar
58psi |
07-21-2011, 07:13 PM | #3 |
EOD
Not sure what the 4 bar is? I'm getting 62 at the fuel rail at idle. Does that sound correct?
07-21-2011, 07:15 PM | #4 |
4 bar = 58 psi.
id say thats about right with 62psi. whats the problem? |
07-21-2011, 07:22 PM | #5 |
EOD
I'm working with Ted to figure out a code P0172 and P0175, bank 1&2 rich. Changed O2 sensors (dealer got them for me under warranty), replaced MAF sensor too. Sent Ted some logs today and he says it's a vacuum leak so I got a PVC cap and attached it with an intake coupler and put 15-20 psi in the top end and there are no leaks. It held the air pressure until I removed the hose.... Even removed a vac line to make sure the air came out and it did. I'm out of ideas...
Ted, if you see this got any more suggestions? Or anyone else.... |
07-21-2011, 07:24 PM | #6 |
what modifications are you running?
and are your properly tuned? i hope you are not paying to replace all these sensors that are easily diagnosable with a volt meter. vaccum leak would cause a lean reading, not rich reading on the o2's. that code would be triggered if the fuel trims were pulling fuel. can you get a datalog of the vehicle at idle or part throttle? |
07-21-2011, 07:27 PM | #7 |
EOD
CAI Inc. intake, DT long tube headers (no cats), Magnaflow comp. catback and Janetty tune... I'm sure the tune is good since Ted has tuned numerous cars with these mods. Has to be something I'm missing?
07-21-2011, 07:32 PM | #8 |
did those codes come up after the tune?
check spark plugs make sure they are torqued correctly and none are misfiring or look funny. |
07-21-2011, 07:36 PM | #9 |
EOD
No, they were showing up before the headers and tune and with stock tune.... Bought the car used and it had Non-stock plugs which I thought were the problem. They were colder plugs.... Now has stock ac delco's but still showing -25 LTFT's (75%).
07-21-2011, 07:41 PM | #10 |
that pcm has only a 25 percent correction anyways.
it could be way richer then that. |
07-21-2011, 08:13 PM | #11 |
Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
Are you using a catch can?
07-21-2011, 08:45 PM | #12 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
I was having the same issue but I had a lean condition at almost +30 LTFT on idle but mine was causing due to vararam intake and my previous tune. After a new tune and its way better.
-25 for you mean that the ecu is trying to compensate for rich condition, completely opposite from what I was going through. What is causing for it to dump fuel like that? hmmmm... |
07-21-2011, 09:00 PM | #13 |
EOD
No catch can. And as for why it's dumping that much fuel, I wish I could find why. Just got in from the garage with the scan tool hooked up. It's starts out around -25 and then is going to about -10.5. Seems it's highest at startup. One question I have is on the scan tool there is an outside temp reading and it is reading -40 deg. Is there a engine sensor that should be reading that correctly?
07-21-2011, 09:31 PM | #14 |
That -40 degree senser could be your prob.
Similar Threads | ||||
defeating the fuel pressure control module... how are you doing it | DSteck | Tuning / Diagnostics -- engine and transmission | 13 | 11-13-2019 10:03 AM |
Anybody Spray'n their SS yet - nitrous ? | WeeZee | Forced Induction - V8 | 37 | 12-29-2012 09:56 PM |
my dyno today(base for e85 tune) | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 51 | 06-08-2011 11:35 AM |
Why RAM Air is a myth!!! Long Read (Wall of text) | live2well | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 80 | 11-02-2009 03:34 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
