06-18-2019, 08:24 PM | #1 |
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
Thinking of going Flex Fuel want advice
I have a Kraftwerks SC with 70mm pulley along with ZL1 fuel pump ADM FPCM and FIC 850cc injectors. I made 590RWHP at 55% duty cycle. I was looking to do the Flex Fuel DSX upgrade. What do you think of adding a BAP and the DSX kit. They say 30% so that would bring my injectors as far as I should go. Do you think I will need more than the BAP? This is probably going to be my last upgrade until I get a newer ZL1.
06-18-2019, 08:47 PM | #2 |
'It's an experiment'
Get the DSX flex kit with aux pump. I did and haven't looked back. Have the ZL1 Pump, BAP, DSX updated FPCM (ADM should be fine).
I also have 1050x injectors on mine too. You may need to bump up to those... -Don
747 RWHP 794 RWTQ
06-18-2019, 09:10 PM | #3 |
Even though my injectors are only at 55% now? I thought it added 30% so that would be 85% unless I misunderstood. That should be pretty good injector wise. However it sounds like you have a SC ZL1 pump modded FPCM BAP and still added a aux pump? Do you have cam headers etc. What kind of RWHP are you at?
06-18-2019, 11:50 PM | #4 |
You’ll need room to grow. You can start with the 850s (I did) but as soon as you add boost, you’ll run out fast. When I pushed past 650 RWHP, it was very obvious I need more injector. I’m at the point again where I’ll need to consider 1300Xs as my next upgrade...
Just a word of caution... your 30% is an ‘estimate’, could be more or less. I’m at 95% without meth, 82-85% DC with meth at WOT... -Don
747 RWHP 794 RWTQ
06-19-2019, 02:35 AM | #5 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
E85 takes a lot of pump and injector with boost.
I made 723 rwhp 93 pump and 760 rwhp E85. I went with: DSX flex fuel sensor ID 1300x ZL1 pump DSX aux pump If I'd known about it, I'd have done the DW400 pump instead of the ZL1 pump though. https://www.deatschwerks.com/blog/de...00-pump-module Just can't find them in stock anywhere....
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
06-19-2019, 08:40 AM | #6 |
Would that single pump eliminate the need for a second pump or a BAP?
06-19-2019, 09:04 AM | #7 |
If you get the DSX aux pump you won't need a bap. A injector upgrade is a solid idea as well. 850s on E85 would be very close to maxed out at your power level. We can get you a package deal on the sensor, the pump and some injectors if you like. We have some pretty solid deals on them.
06-19-2019, 11:55 AM | #8 |
LSx FTW!!!
Thread Tools | |
