Old 01-30-2017, 09:58 PM   #1
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
New to turbos
Just going to throw this out there, hoping to get some opinions/advise.
I have a 2015 1LE and plan to put a twin turbo kit on it very soon. Never ran anything non NA, but have spent some time reading and have a good idea on what I may need. I have an interest in the not yet released Huron Speed Twin kit. I'm not going to go crazy (at first) planing on 600 rwhp / 600 ft/lb at about 8 psi, make it a lot more fun but reliable for a daily driver. My budget is undecided, but I don't want to cheap out and don't want to go nuts.
According to their posts the kit will be mostly bolt on, and includes everything but fueling components. I have the ZL1 fuel pump (1LE), what size injectors should I be looking at?
I plan on keeping the stock internals (for now) other than fuel, is there anything else I should focus on engine wise? Keep in mind I'm going for 600/600. I may swap out cylinder head bolts to be safe.
Since the car will be in the shop and on the lift, I plan on swapping out the clutch to handle the added power. I know that is not necessary, but I usually like to over build and under use.
For now I'm going to keep the NPP 2.5" exhaust and JBA high flow cats. Since it's going to be pretty low boost those should work, right?
Any thoughts or input would be helpful, thanks!
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 01-30-2017, 10:00 PM   #2
Unreal
Drives: 2006 Z06
AGP kit, and done.
Nick
Corvette Z06 -1200ish rwhp
Old 01-30-2017, 10:15 PM   #3
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
I 2nd the agp kit, its been proven to be a great and reliable kit, plus it uses high quality component's that mirror oem quality manufacturing , the only con for some is the turbos are hidden down below, opps forgot one other pro, agps customer service is top notch especially Kevin
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 01-30-2017, 10:51 PM   #4
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
3- to AGP kit!!!! I'm 2014 1le on everything stock 850cc and BAP+ meth kit! I made 672/695 on 12psi and it's safe ! Now I put triple clutch , triple pump with flex on stock long block 807/811 on 13.5psi ! I'm in Ohio and drive car ad DD on winter( just 4 sand bags in trunk on all season tires! AGP very well done kit! Contact Kevin he very helpful!!!!!
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 01-30-2017, 11:09 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
4th for AGP. You're only issue will be making only 600whp
Old 01-30-2017, 11:39 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Originally Posted by Unreal View Post
AGP kit, and done.
Best one out there if going TT...
-Don
747 RWHP 794 RWTQ
Old 01-31-2017, 02:19 AM   #7
AGP Turbo
Drives: All things Turbocharged
+5 AGP
Since you aren't going for the moon on hp, go with some smaller turbos that will spool really quick even on your stock engin. 54/57 in .63 are fast and have made 840whp.
AGP Turbo is offline   Reply With Quote
Old 01-31-2017, 06:53 AM   #8
Buschman
Buschman's Avatar
Okay the AGP kit has my attention.
What injectors should I be looking at for my 600/600 goal that will allow room to add more later? Should I consider spark plugs too?
Will the NPP exhaust work well with the AGP kit?
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 01-31-2017, 06:59 AM   #9
CGbambam
Drives: 2011 Camaro 2SS
I like hellion personally, i like opening up the hood and seeing twins
CGbambam is offline   Reply With Quote
Old 01-31-2017, 07:06 AM   #10
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
Will the JBA high flows and NPP exhaust work well with the AGP kit?
60# would work but might as well get some id850's or equivalent when/if you decide to go more hp
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 01-31-2017, 07:12 AM   #11
Unreal
Drives: 2006 Z06
Kevin can answer all that on the phone while ordering. You can do 850 or 1000cc injectors, it all depends on how much room you want to grow. They also have plugs. Depends on power level. For 600rwhp 1 step colder is fine. If you want to make 800+ later then just plan on swapping them out for some colder plugs later.
Nick
Old 01-31-2017, 07:28 AM   #12
jeff657756
Drives: 2014 SS 1LE
First, your jba cats wont work, but you will reuse your stock manifolds. Second, I give another vote for AGP. I have their kit sitting in my living room and will install it once it warms up a bit here in Ohio. AGP was there to answer my dumb questions and quick to respond when I had an issue. I am not sure what to think about the Huron twin kit. It looks like it may be nice. But also, I didn't see any other kit for sale in the classified section more than their single turbo kits. Your goal of 600 will most likely go up once you achieve it. Might as well prepare to be bitten by the bug lol.
jeff657756 is offline   Reply With Quote
Old 01-31-2017, 07:40 AM   #13
Buschman
Buschman's Avatar
Thanks, just looking (google images) at the routing of everything on the kit and noticing that it bolts directly to the exhaust manifold.
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 01-31-2017, 07:41 AM   #14
jman123
Drives: 2015 Camaro 2SS 1LE
Agp all the way. You'll probably have issues only making 600. I made almost 700 @ 8psi on e85. Also, you'll always want more with the ago there's room to grow. I made 830whp @ 15psi with the base turbos. If I wanted more I would just need to go with some bigger ones, and the kit is has proven itself time and time again.
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
jman123 is offline   Reply With Quote
