01-08-2020, 01:50 PM | #1 |
Drives: hopefully a camaro Join Date: Dec 2019
New Member - need shopping advice
I am looking to pickup a Camaro in the next few months. I have owned a few Chevy's ( S10 Xtreme V6, Silverado w/ 5.3) and also a few BMWs (e30 convertible and e46 coupe). Hence the username...
I will be looking at 2010-2015 SS models in manual. What common problems/issues/factory flaws/maintenance neglect should I look for? I did a search on google and this site but couldn't find anything substantial. I appreciate your guidance in advance! Sent from my SM-G973U using Tapatalk |
01-08-2020, 02:02 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
You did not find much because there is not much. The 5th gen SS manuals are very trouble free, it's the l99 autos that can have problems
Only thing the SS manuals could go wrong is the presser release spring in the oil pump can stick if too much carbon builds up
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
01-08-2020, 02:21 PM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
clutches can be finicky at high horsepower. Stock there really isn't much commonly wrong with them. I have heard there is a blend door problem which can be a nightmare as you have to remove the dash to fix it. I don't switch from full cold to full hot, it actually just stays on cold since I don't drive it on cold days anyway. Just check maintenance records and inspect visually.
01-08-2020, 02:56 PM | #4 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Oil pump failure is the main engine failure they have. Other than that some people have heater cores go out, the head unit for A/C radio, and the stupid blend door breaks
01-08-2020, 03:19 PM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
And replace the battery.
01-08-2020, 03:20 PM | #6 |
Clutch pedal sticking to the floor when drag racing.
01-08-2020, 09:17 PM | #7 |
Drives: 2014 1SS/RS, LS3, NPP Join Date: Feb 2019
The cars are great....enjoy your search.
After you buy your SS be sure to change your username: bimmer2bowtie Lol |
02-15-2020, 06:41 PM | #8 |
Drives: 2011 CAMARO R/S LT2 Join Date: Feb 2020
HI: Im new to the forum and wondering if anybody tell me where i can get keys or a new lock for the gas door. I drive a 2011 r/s the LT model. Have looked on amazon,e-bay with no luck. Looks like the keys are standard and the same for all of them. Guarding the spare now. THANKS BRIAN
02-16-2020, 08:36 AM | #9 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Welcome to our happy little corner of the net, and to Camaro5/6. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, wives', husbands, girlfriends and boyfriends here don't care....and take it easy.
oh...btw....every once in a while a food fight breaks out...so you may not want to wear nice clothes here. Welcome!!
