10-28-2021, 06:54 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Transmission cooler line HELP!!
When I disconnect the 2 cooler lines from the bottom radiator does it supposed to drain coolant also? Or does that drain the radiator completely because I am connecting them to a trans cooler
10-28-2021, 07:21 PM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Trans cooler is a separate unit inside the radiator. There shouldn’t be any coolant at all on those lines.
Are you still using the factory cooler or bypassing it completely? If you still go through the factory one first make sure you get the lines right and it passes through factory first then aftermarket cooler then back to trans.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
10-28-2021, 07:27 PM | #3 |
I want to remove the two bottom hoses coming out from the radiator and connect them directly to the mishimoto trans cooler and to the black fittings hose fittings by passing the radiator is that the correct way to do it?
10-28-2021, 07:27 PM | #4 |
Only thing you should get from those lines is tranny fluid.
10-28-2021, 07:29 PM | #5 |
That's strange I wonder that's why my transmission died it's an aftermarket radiator I haven't seen any coolant in the fluid or is it that coolant surrounds the aluminum cooler while those stock lines are connected?
10-28-2021, 08:42 PM | #6 |
Drives: G8 Join Date: Mar 2012
The trans line is a quick connect fitting. The adapter screws into the trans cooler which seals it inside the radiator. To remove the trans line, you need to remove the clip and pull the tube out.
Sent from my Pixel 4 XL using Tapatalk |
10-28-2021, 10:15 PM | #7 |
Got everything installed now the radiator doesn't hold coolant it leaks out the bottom holes
10-28-2021, 10:48 PM | #8 |
Make sure the manifold? for the trans inside the radiator is seated properly in the holes... And that when you put the adapters back in, you included the washers. You could have cracked the radiator at the holes if it isn't seated correctly
10-28-2021, 11:07 PM | #9 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Sounds like you need a new radiator.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
10-28-2021, 11:28 PM | #10 |
Bought it 4 months back it was the house brand radiator so I'm going with a mishimoto radiator
