12-07-2013, 09:54 AM | #1 |
#1 complaint about running boost
Driving around in 40* weather for a while and then it gets 70* for a few days my car is a turd lol. Its back in the 30s and 40s today and its awesome
The n/a cars I've had run better in colder weather but not like a car with boost. Its turned up a few notches lol.
12-07-2013, 10:13 AM | #2 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
Top mount? The change to warm weather hurts them worse than a centri. You could install the A/C intercooler thing if it is a top mount. For a centri, nitrous cools it back down and makes the air dense again. :-)
Meth works good for both.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
12-07-2013, 10:27 AM | #3 |
I have a front mount. ECS like you but Paxton w/ 9psi.
12-07-2013, 11:33 AM | #4 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Humidity is a bitch with the centri's. I've been in that boat many-a-times. Unfortunately there's nothing you can do about it, at least as far as I know.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
12-07-2013, 07:08 PM | #5 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
12-07-2013, 07:15 PM | #6 |
Drives: 2011RedJewel, FI Join Date: Dec 2011
Maggie here and it loves the cold weather.
12-07-2013, 07:32 PM | #7 |
Even meth doesn't work sometimes. It all depends on the humidity in the air. I mean it helps, but doesn't completely solve the problem. It loves cold weather though. That's one of the reasons I have my car worked on in the winter. Best time to tune and run the car. Turbos on the other hand, since they run off the exhaust, they love all kinds of weather and air density.
12-07-2013, 09:09 PM | #8 | |
Hugger Orange
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80 Join Date: May 2010
12-07-2013, 09:16 PM | #9 |
My Whipple loves the cold air. So my #1 complaint would be traction.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
12-07-2013, 09:29 PM | #10 |
That's all I use is straight meth. I'm in the process now of having a YSi installed right now. So, we'll see what happens. I believe that location has to do with it. You're in Ohio so I would assume that you experience the same humidity as I do. I could be wrong but I'm just saying from my experience.
12-08-2013, 07:56 AM | #11 | |
Hugger Orange
12-08-2013, 10:11 AM | #12 | |
Is that on stock cubes and/or forged? Looks great.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
12-08-2013, 01:09 PM | #13 |
My last setup was an AFR headed 383 sbc, Vortech T trim at 16 psi. It loved pre blower meth to solve the hot humid air problem. I used a Mr Freeze Anderson Ford Motorsport kit that has no electronic parts and used a big nozzle and 70/30 meth/water. If I ever do meth again it will be pre blower. Many people say you lose the cooling effect spraying pre blower but it still cooled the air a ton, cooled the blower and made lots of power.
12-08-2013, 02:15 PM | #14 |
Hugger Orange
It's an LS2 block with callies rotating assy,"404" 102 tb, trick flow 225 heads, squash return style system with e85 pumps at 18psi. 850 wheel with some more left in her. Its all put through a 4l80 and a nine inch. Fun little Bitch to drive, "all street".
