08-03-2010, 07:01 AM | #1 |
Drives: 2013 ZL1 Conv. Join Date: Jan 2009
Extra tools to buy for a TVS2300 install?
I've had my TVS2300 sitting in the corner of the garage for a month now. I wanted to drive my 2011 2SS A6 for a while to flush out any warranty bugs (none found) before installing the goodies.
I plan to install the supercharger myself in a couple of weeks, and was wondering what extra items I should buy to make the install easier. I have most of the following items already, but thought I should check with the experienced folks here to see what other specialty items are either needed or are just really handy. 1. cooler spark plugs 2. clamp removal tool 3. flywheel-holding tool 4. small torque wrench (in-lb) 5. large torque wrench (ft-lb) 6. tub for collecting antifreeze 7. right-angle drill 8. cheater bar 9. ramps 10. six-pack of beverage of choice |
08-03-2010, 11:03 AM | #2 |
Drives: Anything Supercharged Join Date: Apr 2010
redZ28,
You have everything you are going to need to do the install plus all of the tools that are nice to have to make the job easier. As far as the cooler spark plugs go, if you have a stock car and are going to be running the normal 6 psi of boost with our tune, they are not needed. We design our systems to work with all factory equipment. |
08-03-2010, 11:57 AM | #3 |
Drives: 2011 SS/RS Join Date: Aug 2010
The more I think about it the more I want the Magnuson - Does Magnuson offer factory Installation
08-03-2010, 12:47 PM | #4 | |
08-03-2010, 02:54 PM | #5 |
That is definitely a question I would talk to your tuner about, but I have seen plenty of guys running 3.6" pulleys with stock plugs.
08-03-2010, 08:01 PM | #6 |
Drives: 95 bbb impala ss Join Date: Apr 2009
You will need a torque angle gauge for the crank bolt
08-03-2010, 08:05 PM | #7 | |
I just finished up the install of my E-Force and I've got to say the single most helpful tool was a cable operated hose clamp tool. There are lots of tight places where hose clamps are and that tool made it a piece of cake.
Got mine from Sears: http://www.sears.com/shc/s/p_10153_12605_00947390000P Quote:
08-03-2010, 11:06 PM | #8 | |
Drives: 2015 1SS RS 1LE Join Date: Dec 2007
FYI, know Hennessey has opened an install facility in So Cal as well. |
08-05-2010, 11:19 PM | #9 |
Drives: 2010 SIM 2SS/RS MONSTER Join Date: Aug 2009
maybe a fat sack of sticky green ...... wait your not in cali !
HP MONSTER' SOUTHERN CALIFORNIA BUILT, LMR CAI, CUSTOM GRIND CAM, CUSTOM BUILT CNC PORTED AND POLISHED HEADS, FAST 102MM INTAKE MANIFOLD,ARH LONG TUBES AND HIGH FLOW CATS, BIGGER INJECTORS, VALVES SPRINGS RETAINERS, MGW SHORT SHIFTER, EIBACH SPRINGS, FACTORY CHROMED WHEELS, BLACKED OUT EMBLEMS, BLACKED OUT ROOF,BLACKED OUT MARKERS, 3.5 INCH ELECTRONIC CUTOUTS, FLOWMASTERS, ZEX WET 150 SHOT, FOR A GRAND TOTAL OF =630 REAR WHEEL TORQUE ,AND 600 REAR WHEEL HORSEPOWER
MY JOURNALhttp://www.camaro5.com/forums/showth...02#post2023802 SOON TWIN TURBO SETUP |
