12-17-2013, 09:33 AM | #1 | |
Black Widow
Drives: 2014 Camaro 427SS Join Date: Nov 2013
800rwhp - First Phase of the build complete!
2014 Camaro 2SS/1LE 6.2L 376c.i. LS3 Manual 6-Speed, 3.91 Rear Differential 100% Built/Tuned/Maintained by Lethal Racing Powertrain Mods *Whipple 2.9L Supercharger w/ 3.5" Pulley & Air-To-Water Intercooler @ 13psi Boost *Lethal Racing Custom Night Fury Camshaft *LS3 Cylinder Head Upgrade - Manley .700 Dual Valve Springs & Retainers, Comp Cams LSX Rocker Arms & Trunnion Upgrade, ARP Head Studs *Lethal Racing 5/16th 7.400 Hardened Pushrods *ARP Camshaft Bolts *Stock Crankshaft, Connector Rods, Pistons, and Bearings *Stainless Works 1 7/8" Long Tube Headers *Catalytic Converters Deleted & NPP Exhaust Deleted *Ported Throttle Body *Cold Air Inductions CAI & High Flow Cone Filter *C5R Timing Chain & GM 3-Bolt Timing Gear *Melling 10296 Oil Pump *Lethal Racing Gasket & Seal Package *ECS Alky Control Single Nozzle Methanol Injection System * Stock ZL1 Fuel Pump & Siemens 63lb/hr High Flow Fuel Injectors *MSD Fuel Pump Booster *NGK Spark Plugs *Mobil-1 Synthetic 5W30 Engine Dress Up Mods *Holley Valve Covers - painted GM Victory Red *OEM 1LE Strut Tower Brace - painted GM Victory Red *Billet Fluid Caps w/ Carbon Fiber Inlay *Billet Fuse Box Cover *Billet ECM Cover *Billet Oil Fill Cap w/ Filter Breather *Custom Lethal Racing Decals Exterior Mods *MPD1 Z-Force Ram Air Hood *5% Suntek Window Film *Custom Supercharged 1LE emblems by EmblemPros *Custom "Black Widow Edition" Decals by Trinity Graphx *Carbon Fiber Bow Tie Emblem decal overlays *Xenon Hyper Blue HID Bulbs - Low Beam Headlights *Xenon Hyper Yellow HID Bulbs - Fog Lights *Mickey Thompson ET Street Slick Radials (305/35R20-Rear) *Custom Lethal Racing Decals Interior Mods *Custom Supercharged 1LE emblem by EmblemPros *Custom "Black Widow Edition" embroidered Leather Seat Head Rests by Trinity Graphx *Hurst Short Throw Shifter *ZL1 Aluminum Brake, Clutch, Accelerator Pedals *93 Octane Pump Gas/Methanol Injection indication LED's *Lethal Racing Custom ECM Toggle Switch - On The Fly conservative/aggressive ECM Tune Change
100% Lethal Racing Built/Tuned/Maintained *Black Widow Camaro 427SS* Last edited by 1 BADD 1LE; 12-18-2013 at 09:42 AM. |
12-17-2013, 09:47 AM | #2 |
WOW !!! Impressive results. Also , thanks for the extra detail on listing components used. I'm amazed to see that much horsepower being made on the 63 lb injectors. Am I to assume most people are on larger than needed injectors ? In any case, another awesome ride !
12-17-2013, 10:29 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
800rwhp with just a zl1 pump and boost a pump? That cant be safe
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
12-17-2013, 10:41 AM | #4 |
Drives: 2x 05 Vettes/65'AC cobra/68 camaro Join Date: Apr 2009
VERY NICE CAR though! clean looking! have fun with it! dont ever get bad gas or hit to many rev limiters with that HP on that stock bottom end, thats alot of HP on a stock bottom
12-17-2013, 10:51 AM | #5 |
Black Widow
Not to worry, it's not gonna be stock for long - going with a fully forged motor this coming summer! All I can say is Shawn "The Mad Scientist" David at Lethal Racing knows what he's doing! My car is tuned down to 750rwhp on the street, and my ZL1 Fuel Pump, MSD Fuel Pump Booster, and 63lb/hr injectors are working just fine with the M1 Methanol injection upstream of the MAF and the tune...We also have the Rev limiter set lower than what the engine can actually turn - Lethal Racing knows what they're doing!!!
100% Lethal Racing Built/Tuned/Maintained *Black Widow Camaro 427SS* |
12-17-2013, 11:40 AM | #6 | |
have fun with it! |
12-17-2013, 11:58 AM | #7 |
M6 9 second club
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
Awesome build man!
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff #BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning Check out my youtube channel: http://www.youtube.com/user/6410Jrod Follow me on Instagram: @J_Rod6410 |
12-17-2013, 12:15 PM | #8 |
Drives: 2010 2SS/RS Join Date: Mar 2010
Congrats on the build - super bad ass.
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers "Information is the oxygen of the modern age" Build Thread |
12-17-2013, 05:12 PM | #9 |
I noticed the methanol injection. After I posted. I just didn't realize it was that much of an impact but obviously it is. Again, impressive !!
12-17-2013, 05:20 PM | #10 |
5Th Gen (Craig)
Great build....
2014 C7
12-21-2013, 11:39 AM | #11 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Can't believe you don't have belt slip...
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
12-21-2013, 12:37 PM | #12 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
Are you using the stock FPCM or the ADM? If stock, your pressure must be dropping a lot on a long hard pull on the street or on the track. If not, even with the meth, I'm not sure how it isn't dropping off.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
12-21-2013, 12:58 PM | #13 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Freakin awesome dude!!!! totally has the muscle to back up the looks!! Looks awesome!!!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
12-21-2013, 05:10 PM | #14 |
Drives: LSx Performance Specialist Join Date: Jul 2011
Geez...... You guys never seen a ZL1 pump 63lb injectors and Meth(Dual Nozzle) make 800rwhp? The fuel pressure was closely monitored as well all A/F ratios. Being a stock block the car did not leave with that much power. There will be a much better fuel system on the car soon along with ID850+ and we won't be having this discussion. We made 715 before the pulley and meth. The meth helps a lot in terms of extra fueling, octane rating, and cooling.
