01-03-2019, 07:05 AM | #1 |
Drives: 2018 2ss 1le Join Date: Jan 2018
engine dress up with msd manifold
I have the msd in grey and black
now that I have no plenum cover or fuel rail covers, I want to dress it up a bit, I am going white and black or grey theme..... like my roto fab dry (white and black) any suggestions |
01-03-2019, 02:29 PM | #2 |
Drives: 2016 Camaro 2SS A8 Join Date: Dec 2015
I am planning to add the Katech valve covers with the coil relocation kit with the longer wires.
You can get the wires and covers in grey I think Picture below: https://www.google.com/search?q=kate...GzaacGNebbrPM: |
01-03-2019, 03:04 PM | #3 |
Drives: SS 6 speed of course Join Date: Jan 2016
When I win the loto I'm doing this:
https://vengeanceracing.net/vengeanc...ouse-only.html
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
01-03-2019, 04:07 PM | #4 | |
Drives: '17 SS/1LE/PDR Join Date: Feb 2017
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
01-03-2019, 06:26 PM | #5 |
yeah but that will never happen.. they will only install them themselves
when you bought your rotofab did it come with the red overlay for the badge, that will look good on your combo.. which coolant cover is that, I like it, also river city has custom billet caps but that's 200 that I feel I could use somewhere else first |
01-03-2019, 06:30 PM | #6 | |
https://store.katechengines.com/cust...overs-p52.aspx https://www.roto-fab.com/coolant-expansion-tank-cover
01-04-2019, 11:51 AM | #7 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
I just used the oem covers.... I honestly hate the way the MSD looks exposed....
However to change it up a bit i plan on painting the coilpack covers red... and taking off the fuel rail covers.. A bit dirty in this pic, sorry
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
01-04-2019, 02:45 PM | #8 |
how did you get them to stay
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
01-04-2019, 03:01 PM | #9 |
@Blackmamba_1LE
They just do, the rubber tabs that "blend" into the coil pack covers hold them in place.
01-04-2019, 05:36 PM | #10 |
Drives: Camaro Join Date: Sep 2018
Can you put the silver stock center cover back on?
01-04-2019, 05:39 PM | #11 |
01-04-2019, 05:56 PM | #12 |
its the oem part from the convertible camaro, brace. People claim that its unnecessary on the coupes, guess they've done independent testing lol.
Regardless, I might have to loose it. Unsure if my Katech coil relocation kit will clear underneath it.
01-04-2019, 08:00 PM | #13 |
you can't put the plenum cover back on...
and its called a strut tower brace, most say its not needed but I still wanted one... ive had them on all my cars
01-04-2019, 10:32 PM | #14 |
@Blackmamba_1LE
Never tried honestly
