#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 06-09-2018, 01:04 PM   #1
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
ZLI ADD ONS LIFT POINTS
Just ordered. Has to make life easier and safer at dealer.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 06-09-2018, 01:10 PM   #2
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
best thing I did for the car
I also ordered some pucks and use them to actually do the jacking and then I use the lift points to rest on the jack stands
I can have all 4 wheels of the ground in less than 10 minutes
biker2k is offline   Reply With Quote
Old 06-09-2018, 01:14 PM   #3
Chris C 1SS 1LE
Drives: 2017 1LE
Nice. What pucks did you go with? My jack stands are V shaped. i have a pad on my floor jack so think it would be OK
Old 06-09-2018, 01:18 PM   #4
biker2k
biker2k's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I use two stacked on one another to clear the body work...
also I bought rubber protectors at harbor freight for my jack stands
sorry don't have a link for that
ill add pics one of these days but I put the lift points furthest away from each other and then there is another jack point I use with the pucks
Old 06-09-2018, 01:23 PM   #5
Chris C 1SS 1LE
Drives: 2017 1LE
Tracking. have the same lift stand protectors. Tango.
Old 06-10-2018, 07:31 PM   #6
Chris C 1SS 1LE
Drives: 2017 1LE
Those arrive tomorrow. Thx.
Old 06-10-2018, 08:30 PM   #7
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
need to order a set soon.
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 06-10-2018, 08:40 PM   #8
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Mine are scratched up from jack stands...but my pinch welds are scratch free.
2017 H50-2SS-MN6-F55-NPP-RIK-WL4-IO6
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
Built - 8/2 - PS 1,182/1 of 699US
4300 - 8/3
5000 - 8/5
6000 - 8/13
KyBoy is offline   Reply With Quote
Old 06-11-2018, 11:02 PM   #9
Chris C 1SS 1LE
Drives: 2017 1LE
Amazon stuff Arrived today neighbor wants some too. 17 bones and prime delivery. Appreciate the link and the fit is perfect do have C7 side skirts too
Old 06-12-2018, 11:44 AM   #10
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
Those ones on Amazon do you have to stack 2 or will 1 clear the plastics?
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 06-14-2018, 08:14 AM   #11
Turbo_J89
Drives: 2015 BVM Camaro 1LE (2SS/RS)
I ordered 2 sets of ZL1 Add-ons Jack Pads and use 1 full set to support the Jack stands and 2 more pads mounted to the floor jack points works great. No need for pucks.
Turbo_J89 is offline   Reply With Quote
Old 06-14-2018, 08:09 PM   #12
bullet3z
Drives: 2018 1SS 1LE
I just put on my ZL1 lift pads without lifting the car. Let's just say that was a pain. It is not easy to do while laying on the ground.
bullet3z is offline   Reply With Quote
Old 06-15-2018, 07:42 AM   #13
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
To me the jack points are must have mods on this car! The pinch weld is so far recessed that its pretty unreachable without some sort of jack point.
mjk3888 is offline   Reply With Quote
Old 06-15-2018, 11:43 AM   #14
MJP
MJP's Avatar
Drives: 2018 Camaro 1LE Summit White
It's like a slut running loose in hell just trying to get our car off the ground.
We have to purchase this and that. The correct jack. The correct stands. The correct adapters.
It's all to blame for that aluminum cross member up front... Do we even have a cross member up front underneath all that plastic?
I don't understand it. I lifted my C6 Vette from the aluminum CM at the front several times.
Has anyone removed the plastic to see what we're working with?
I would use two floor jacks at the same time to lift my C6 Vette straight off the ground.
Rear Dif and the Aluminum front CM.
One Jack in the rear, one in the front.
Set her down on the stands with aluminum pucks in the factory keyed fittings.
MJP is offline   Reply With Quote
