08-28-2018, 06:27 AM | #1 |
Drives: 1993 z28/2010 2SS Join Date: Aug 2015
Long tube headers with rear o2 sensors ?
Has anyone installed long tube headers and installed a reducer behind the cat with o2 sensors ? I’ve heard some say the o2 sensors would be too far back to read properly but should that be an issue if the o2 sensors are heated ?
08-28-2018, 07:54 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
you can adjust those settings with a tune. no need to add reducers or o2 sensor simulator
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
08-28-2018, 08:22 AM | #3 |
Well that’s the problem I’m having right now is finding someone to do a tune
08-28-2018, 08:47 AM | #4 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
Plenty of mail order tune places that can set you up with a tune to remove those rear 02 sensors since they aren't needed.
08-28-2018, 09:11 AM | #5 |
08-28-2018, 09:49 AM | #6 | |
what headers did you install? the rear sensors should be tuned out, and the front o2 sensor settings will need to be adjusted for the increased distance from the exhaust ports.
2010 2SS/RS
08-28-2018, 01:53 PM | #7 |
Drives: cars Join Date: May 2011
08-28-2018, 05:12 PM | #8 | |
Drives: 10 2ss/rs Join Date: Jul 2018
So like he said no real purpose
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
08-29-2018, 02:30 AM | #9 |
Drives: 2014 2SS/RS Join Date: Jan 2018
There is literally no reason to have the rear sensors if you don't have cats.
Sent from my SM-N950U using Tapatalk
2014 2SS/RS LS3/M6
08-29-2018, 02:36 AM | #10 |
I still do have cats, a mustang guy already told me to take them off cause they create too much backpressure 😂. It’s super loud already even with cats, I get looks from cops a lot and have to baby the throttle
09-04-2018, 08:44 PM | #11 |
So I’ve been going back and forth with this tuner in town for a week. Now he tells me he can’t do anything for me unless I have rear o2s, and told me to go to an exhaust shop and have some bungs installed. What’s the point of the tune if I have rear o2s ?
09-04-2018, 08:50 PM | #12 |
Drives: 2015 1LE Join Date: Oct 2015
My Kooks cats had O2 ports already in them but I would imagine that if you had the bungs welded in a few inches downstream it would be fine. I had PatG do remote tuning on my car and he did a good job FYI. https://www.guerragroup.com/efi-tuning
09-04-2018, 08:58 PM | #13 | |
did you ever get a tune after or have any issues passing smog ? i mean if i put rear o2s on kinda defeats getting a tune minus performance wise |
09-04-2018, 09:18 PM | #14 |
I got a tune directly after installing the headers and hi flow cats. I live in Ohio and must get an E-Check. I did pass it because in the tuning software they turn off the codes that report issues from headers and hi flow cats. Installing rear O2's does not defeat getting a tune at all. It may help the tuner with dealing with all of the codes/issues assostated with just deleating them.
