Old 09-08-2014, 06:52 AM   #1
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
Anyone running a Boost A Pump with the stock fuel pump?
If so what kind do you have and what's your rwhp?
Thanks
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 09-08-2014, 08:17 AM   #2
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
KB here installed by LMR & now I am @640rwhp on a Mustang Dyno .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 09-08-2014, 08:43 AM   #3
TripleBlkZL1
Ahmad
Very nice numbers.. any issues with the BAP and how much boost are you running?
2018 2500HD Duramax
Old 09-08-2014, 09:30 AM   #4
alssiri
alssiri's Avatar
No issues, was 14psi but didn't check after adding LG H/C kit maybe dropped 1 or 2 psi.
Ahmad
2012 ZL1 A6 (SOLD)
Old 09-08-2014, 11:26 AM   #5
TripleBlkZL1
Ahmad
I'm curently at 580rwhp mustang dyno on 91 octane. I'm adding a custom aggressive cam from Cunningham Motorsport and back to 93 octane. I should be ok without the BAP because I know it's good for 650rwhp. Thanks for the information
2018 2500HD Duramax
Old 09-08-2014, 11:46 AM   #6
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
I'm over 650 whp, run id850 injectors and added a boost a pump as well. I'm at 13.9 lbs of boost.
mrvenicess is offline   Reply With Quote
Old 09-08-2014, 12:50 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Are you sure about that? Have you logged fuel pressure during a WOT run? You'd be surprised to see how soon the fuel pressure starts to drop.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-08-2014, 06:22 PM   #8
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
KB BAP at 673 rwhp.
2012 #1765: Xpel Clear Bra, 15% Tint, M2W, LPE GT9 Cam, Ported Heads & Snout, Upgraded Valve Train, 90mm TB, LPE Dual Fan HX, 2.55 Upper, 9.1 Lower (18%), Id850's, KB BAP, Roto-fab CAI, AR Stainless Headers, 673 rwhp, A6, Nothin but Fun!
AZ-ZL1 is offline   Reply With Quote
Old 09-08-2014, 07:17 PM   #9
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Kenne Bell boost a pump here Deka 60LB injectors 13LBS boost 580rwhp
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 09-09-2014, 03:26 PM   #10
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
I'm running ID850's with BAP and Stock Fuel Pump - 700RWHP with no issues (to date! )
15PSI Boost
Modern07 is offline   Reply With Quote
Old 09-14-2014, 07:57 AM   #11
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
KB BAP by LMR @750RWHP with no issues.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 09-14-2014, 11:58 AM   #12
Alexzl1
Alexzl1's Avatar
Drives: 2013 zl1 A6 summit white
Msd bap with id 850 . 15psi 640whp mustang dyno
'13 A6 ZL1 . JLT cold air , SW 2" longtube catted, LS3 TB, 2.55 upper+ ati balancer w 10% lower . LPE cam, ID 850, msd boost a pump . Fabco HX . Best et to date 10.86 @126mph .
Alexzl1 is offline   Reply With Quote
Old 09-16-2014, 07:32 PM   #13
Oddvious
Oddvious's Avatar
Drives: 2013 ZL1
Id 850 635hp Mustng dyno no issues without one 6mo now
Oddvious is offline   Reply With Quote
Old 09-16-2014, 07:45 PM   #14
Suprslo
Drives: 2013 SS
Stock fuel pump with KB BAP. 709 rwhp 12 psi for 2 years now and about 30 1/4 mile runs.
Suprslo is offline   Reply With Quote
