12-05-2016, 09:57 PM | #1 |
Drives: 2011 2 ss/rs Join Date: Jan 2014
****injectors*****
I have a 2011 ss and am going twins this winter. Having trouble picking injectors. The Holley 120's are very affordable but haven't found much pros or cons on them plus there not direct fit. . The ID 120's are almost $1000 more are they really worth it?? I know you get what you pay for with most performance parts, but I'm not building a pro mod. Thanks in advance!
12-05-2016, 10:50 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
You're looking in the wrong camp (Holley). Try a Google search for Camaro LS3 injectors. That will, at least, show you what you should be looking for - e.g. Injector Dynamics, Fast, FIC, FIC (the other one), Bosch, Deatschwerks, etc.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
12-05-2016, 10:53 PM | #3 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
There is only one person who should tell you what injectors to buy and that is the person who is going to tune the car
Fic 1000s here
12-06-2016, 09:14 AM | #4 |
8.60 @ 157 @ 4200lbs
Bigger question make sure you have fuel system to support horsepower and injectors for the build see so many dont upgrade to correct fuel supply,
But if your serious Hp Injector Dynamic 850 or 1000 its better to pay a little more now than to find out you have to turn around sell a set and end up buying a better injector to support what you are shooting for. I see so many short cut the fueling because of cost but fuel is life line to the motor. |
12-07-2016, 02:12 PM | #5 | |
Drives: 2010 2SS Join Date: Oct 2014
Screenshot from here: http://fuelinjectorclinic.com/hp-calculator |
12-07-2016, 02:40 PM | #6 | |
Too much is never enough!
