Old 07-02-2018, 08:38 PM   #1
jbassking
Drives: 2012 SS
Measuring cam lift without removing cam
I want to double check the lift of my cam but don't want to take it out. I figured if I remove a valve cover and measure the height of the spring when the valve is closed and subtract the height when it's fully open, I should get the overall lift but the numbers just aren't even close.
Am I missing something here?
jbassking is offline   Reply With Quote
Old 07-02-2018, 08:44 PM   #2
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I did the same thing. When engine is off the lifter isn't pumping up and bottoms out. So you have to add in the lifter travel x the rocker ratio and add that to your valve lift. If I understood correctly.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 07-02-2018, 08:49 PM   #3
jbassking
Drives: 2012 SS
How would I know the lifter travel?
Old 07-02-2018, 09:06 PM   #4
jbassking
Drives: 2012 SS
I think the standard is .050 but I could be wrong.
Old 07-02-2018, 09:14 PM   #5
go_go_gadget88
I wanna say total lifter plunger travel to bottom is .200 for a stock ls3 lifter
I could sure be wrong so do some looking. Its more than .050 for sure. I have more preload than that so I'd be bottomed out lol.
