10-04-2022, 12:24 AM | #1 |
2010 SS A/C Noise
Hey all.
I recently noticed that my air conditioning is underperforming. The compressor is engaging and spinning. However, it’s very noisy. There’s also an evident hiss that can be heard from inside the cabin. The compressor noise fluctuates with RPM, but the hiss sound is constant. If you’d like to take a listen, click the link below. It only hisses when the A/C is on and it doesn’t do it when the heat is blowing. Any ideas on what the issue can be? This is the first time I’ve heard a hiss like this. https://youtube.com/shorts/cjrlw3A53Oc?feature=share Sent from my iPhone using Tapatalk
10-04-2022, 06:25 AM | #2 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
It's low on refrigerant
10-21-2022, 07:25 PM | #3 |
Drives: '15 Z/28 #0270 Join Date: Jan 2017
Mine sounds like that to. Except when I first turn the ac on theres a short bird scream noise and a hum that goes with the engine rpm's. That's just low refrigerant?
10-21-2022, 08:38 PM | #4 |
Drives: 2013 SS Camaro Join Date: Oct 2018
10-22-2022, 02:27 PM | #5 |
Thanks! Will update when I bring it in.
