#Camaro6
AWE Tuning
Old 02-01-2023, 09:46 PM   #1
RyPG
Drives: 2018 camaro zl1
My zl1 keeps loosing boost because knock sensor even after replacing it
so pretty much, i was getting a code for knock sensor and everytime i push the car to the limit the engine light comes on and i loose a lot of boost of the supercharger the code for knock sensor comes up but after the car been stopped for a few hours it goes away so i decided to replaced it but still everytime i drive using the full power of the car after few minutes it comes back again. i dont know what to do its so annoying when the power is reduced. what should i do?
p.s a performance mechanic changed it for me.
RyPG is offline   Reply With Quote
Old 02-01-2023, 11:46 PM   #2
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
If it's loose (as you wrote a couple of times), tighten it.
(A knowledgeable person will hopefully be along shortly to provide a substantive response)
ohsmily is offline   Reply With Quote
Old 02-02-2023, 12:22 AM   #3
HDRDTD
Any chance you have some air in your SC cooling system?
Old 02-02-2023, 02:56 AM   #4
65ffr
65ffr's Avatar
Drives: '18 ram 1500
what octane gas are you running? That might be typical with 91
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
65ffr is offline   Reply With Quote
Old 02-02-2023, 06:51 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
flashing check engine light is a misfire, you didn't really say what you got as far as the light, just the knock sensor. Too, like above, what octane are you running.
WhiteMale is offline   Reply With Quote
Old 02-02-2023, 09:12 AM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
We need more info...
1. Please list all performance mods
2. What is the mileage on the car?
3. How old are your spark plugs?
4. Do you run a catch can?
5. What fuel do you use?
6. What are the ambient temps when this happens?
7. What are your cooling temps when this happens?
8. Have you ever "burped" your SC cooling system?
9. Any changes made before this started happening?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 02-02-2023, 09:30 AM   #7
RyPG
im always running on 93!
Old 02-02-2023, 09:34 AM   #8
RyPG
1. only roto fab intake
2. 60300
3.brand new spark plugs changed last month
4. no
5. i always put 93
6. when this happen it's usually a little cold like 40 to 50 outside
but the car temp never gets hot
8. i dont know what is that
9. no i got the car with 58k wasnt doing that until i started to really push it like going over 120mph
Old 02-02-2023, 09:35 AM   #9
RyPG
no misfire was detected everytime engine light comes and put the code reader
it comes p0325 always 93 octane
Old 02-02-2023, 09:36 AM   #10
RyPG
you are the second person to say. i really dont know what that means to be honest. ill look at up
Old 02-02-2023, 11:05 AM   #11
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Wait back up please. Anyone offering advice in this thread not related to his initial problem is not reading properly.
What are the DTC codes the engine is throwing for the knock sensor. There are 2 sensors , and need the codes it’s throwing.
If you replaced the knock sensor and it’s still throwing knock sensor codes it could be the wiring for the sensor, it’s right near the exhaust.
Also any codes for a knock sensor put your car into the low octane table which is why you have no power.
We need the codes it’s throwing to help you.
Has nothing to do with air in your SC loop, that’s a completely different issue.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 02-02-2023, 02:26 PM   #12
Blackbyrd
Drives: Chevy Camaro ZL1
had this problem with my 06 GTO. I purchased it used with headers, and they didnt route the knock sensor wires away from the primaries. So after I couldnt get the code to go away knowing the car wasnt knocking) I ordered a pair of sensors. I found when I was replacing them that the wires were burned through.
Blackbyrd is offline   Reply With Quote
Old 02-02-2023, 02:31 PM   #13
WhiteMale
yep I agree OP says it's p0325...I'd check those wires aren't' burned/chafed/broken
Old 02-02-2023, 06:14 PM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
P0325 is the knock sensor on drivers side on the block. Due north of oil filter.
It’s either going to be the sensor or wires.
You need to unbolt the heat shield, 1 bolt then unbolt the knock sensor.
You sure you replaced the correct one ?
annoying, boost, help me please, knock sensor, zl1
