01-10-2019, 03:26 PM | #1 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
passenger side lights are out
So the other day I noticed my passenger fog light went out. Ordered new ones online and they came in today. I swapped the bulb and it still wont turn on. When I started checking it out I noticed the passenger side sidemarkers both front and rear aren't on either. Any ideas here? the "fog lamp" fuse looks fine. Also, all the lights on the driver side work perfectly. Any ideas? im stumped
Adam
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
01-10-2019, 03:43 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Check your wiring harness...
Could be your BCM too. Lights start acting weird when it starts going out. My passenger tail lights went out and fuses looked fine too. After troubleshooting and finally taking it in for service, it turned out to be my BCM. It'll cost you about 600 to fix if not under warranty. The part alone is around 450. Good luck. |
01-11-2019, 06:48 AM | #3 |
New update: Came outside today and noticed the rear passenger marker light is in fact working. So now its just the front passenger sidemarker and passenger DRL ( Fog light ) that isn't working.
01-11-2019, 03:53 PM | #4 |
Well yea, something is definitely wrong here. Took a ride to my warehouse for work and everything was working. Just went outside to grab a smoke and turned on the lights and everything on the passenger side is out again. GRRRRR
01-11-2019, 04:04 PM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Rats?
01-11-2019, 04:09 PM | #6 |
01-11-2019, 04:11 PM | #7 |
I'm going to laugh when OP finds chewed up wires.
01-12-2019, 01:17 PM | #8 |
Ground wire?
Lusinda 2010 2SS/RS |
01-12-2019, 01:31 PM | #9 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Check the bumper harness, if you got one of the cheap DRL harness , that are made in that long a way land, its more then likely it corroded terminals inside, there don't come with seals and cavity plugs, that allows water to get in.
01-14-2019, 12:19 PM | #10 |
Thanks for the help... Dick
01-14-2019, 12:20 PM | #11 |
I do have one of those Amazon DRL harnesses that I threw on the car about 5 years ago. I think im gonna order one from you guys and swap it out. Its cheap enough to give it a shot before I go the BCM route
01-14-2019, 04:23 PM | #12 | |
376 cubic inches of fun
My rule with late model cars is: no electrical enhancements ever. Guaranteed can of worms. Example: after market radio installed, resulting in DRL function killed off. |
01-15-2019, 12:37 PM | #13 |
Normally I would have mentioned it up front but I did have this thing installed for the last 5.5years with no issue so I didn't think anything of it. Good point though
01-15-2019, 01:36 PM | #14 |
At the last Camaro fest had a costumer that had the cheep DRL eat true his bumper harness terminates, we had to solder a new pig tale on the car, that was lots of fun in summer outside in the heat, but that fixed it.
