11-20-2012, 07:34 PM | #1 |
NT05r or NT555r?
I am about to get some new wheels and it'll be a 20x11 rear wheel. What I am trying to figure out is what's the best tire to run for it. I would like to try out a drag radial since most street tires dont stand a chance hooking with my car's power/gear. Im leaning towards the nt555r at the moment as the car is daily driven and not really wanting to replace tires every 3 months. What kind of mileage is everyone getting out of their nittos, whether it be the nt05r or nt555r? How well do the 555r's hook in comparison to the nt05r? Thanks for the input!
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
11-20-2012, 08:43 PM | #2 |
Drives: 2013 ZL1 Join Date: Oct 2012
Ur making 462 rwhp and can't hook? Hell even nitto invos would do the job.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1 |
11-20-2012, 08:47 PM | #3 |
My cam makes pretty good low end power plus the 3.91 gear... the mt street comps on there now spin in 2nd.
11-20-2012, 08:51 PM | #4 |
When is enough ever...
Drives: 2006 Silverado 2500HD CC/SB LBZ Join Date: Apr 2011
Location: Residence: Chula Vista, CA Home: Billings, MT
Definitely not the 05R's if this is driven on a regular basis. A couple reasons:
First, they are a slick down the center with a small amount of tread on the outside should of the tire. This thing would be all over the road in even the slightest rain. Second, they wear fast. I only put mine on for the 20 mile drive to the track and they are wearing pretty quick. As for the stick, they do pretty well but launching the LS3 is a science and even more so when you factor your mods. You're making about the same power as me. Bottom line, for a daily driver I would do no more than the 555's but you might consider saving yourself the headache and running a street tire for the daily driver bit and have a spare set with NT05r's for strip duty. Good luck.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing |
11-20-2012, 09:30 PM | #5 | |
11-21-2012, 08:29 AM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
NT555Rs if its daily driven and will see some rain. NT555Rs actually have decent tread life (much better than the NT05R). Some guys get 8k miles out of them. It all depends on how often you go to the track.
11-21-2012, 08:38 AM | #7 | |
My car is only making 360 rwhp and the Invos wouldn't hook up at all on the street (from a dig). |
11-21-2012, 08:56 AM | #8 |
Ive never used drag radials so im wondering what psi do you run on for street use? Also track use?
11-21-2012, 09:38 AM | #9 |
I run 36 PSI to get to/from the track and air down to 18 for racing. Also keep in mind DR's are going to effect handling. Your car is not going to be a canyon carver with DR's on so expect some decreased cornering performance when on the street.
11-21-2012, 10:45 AM | #10 |
MTMTEYE
Drives: 2010 Camaro 2SS Join Date: Jul 2010
I was debating between NTO5, 555s and Invos myself, [not the Rs] as a daily driver tire for this summer coming up, Rain can be heavy but its so hilly that water never settles on the roads here. Also my car that is a DD isn't track raced at all. And I have seperate wheels/tires for winter.
MTMTEYE
2010 2SS/RS M6 Aftermarket bolt on parts and tune.. 434hp/395tq Daily Driver. |
11-21-2012, 10:53 AM | #11 |
I also debated going with a regular nt05 but i think theyll do just as good as my mt street comps...so ill give the 555r a shot. I drive pretty conservativly 95% of the time
11-21-2012, 10:54 AM | #12 |
I have tried both of them and I prefer the NT05r's. They are a softer compound and have more of a contact patch.
Now, with that being said............... I now have some M/T ET street radials, and these things are awesome!! I hook every time. |
11-21-2012, 10:55 AM | #13 |
i use nt555R's on my hhr when i go to the track, i know its a little different but i would not want to drive around on those 555r's very sticky and for my car being front wheel drive, i was having a lot of trouble turning the wheel at low speeds. i agree with these guys, get some invos for the day and buy some 18" wheels and mount nt05R's on them for the track.
2009 Pontiac G8 GT M6
Kraftworks Built Forged 10.3-1 LSA w/ Ported/Polished LS3 Heads, Kraftworks spec Cam Motion billet Cam, LSA Blower/2.50 ADM Griptech, Lingenfelter ZR1 Clutch kit, Camaro SS 3.45, ProMotion Built TR6060, Kooks 1-7/8 Longtubes w. Catless Solo Connection Pipes, Solo Mach Shorty Catback, Rotofab Intake, Eibach Springs, G8Only Splitter with custom turnbuckles, 20x9.5 and 20x10.5 Sapphire Blue Forgestar F14, CTS-V1 4 Piston Brembos/w SS lines |
11-21-2012, 11:10 AM | #14 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I've been daily driving on the 555R's on 20x9 rims, and they've seen heavy rain and temps down to 33F here. They drive great on the street. What are the treadwear ratings of both tires? Usually the higher the treadwear, the longer they last. Mine don't look worn at all. But they might not work out for me long time. I won't DD on low treadwear tires because I'd hate to go thru two sets a year.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
