07-26-2020, 09:22 PM | #1 |
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro Join Date: Jul 2016
Have CAI/Tuner Where to get Pulley Setup
Hello
I have a CAI and the SCT tuner. Where would you recommend getting the lower pulley/belt setup from when the time comes? Thanks, Ed |
07-26-2020, 10:15 PM | #2 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
07-27-2020, 02:28 AM | #3 |
Drives: 2012 ZL1 Join Date: Mar 2020
The dayco/powerbond pulleys are pretty good and way cheaper than everyone else
PBO1662SS10 is the part number for 10%, not sure if they have bigger.
'12 ZL1 - RPM 5", TSP 2" headers, Speed Engineering 3" header back, Dayco 8.66 lower/LPE 2.38 upper with solid isolator and 10 bolt hub, hand ported blower and snout and went way too far, ID1050x's, DSX aux harness with a summit 400lph pump on E, NGK TR8's with Taylor wires, 160* tstat, NW 102, UPR catch cans, HP Tuners, Stock unopened long block
07-27-2020, 05:22 AM | #4 |
Drives: 2013 zl1 vert Join Date: Dec 2018
They do have bigger pullies. I have their 22.5 lower.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
07-27-2020, 01:51 PM | #5 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
You do realize the OEM is one piece so you must get a balancer and pulley that is aftermarket. On those, like the ATI I have, the pulleys can be changed out on their balancer. A low quality balancer can leave crankshaft vibrations and breakage internally.
07-27-2020, 02:51 PM | #6 | |
Ya get what you pay for here.. |
07-27-2020, 03:00 PM | #7 |
Yes. I know you need a balancer as well.
07-28-2020, 07:03 PM | #8 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
