08-12-2019, 11:38 AM | #1 |
Drives: Chevy Camaro Convertible Join Date: Aug 2019
2015 Convertible Top Not Working
Hello -
Hoping I might get some answers/insights from other convertible owners... My top will no longer go down, just happened out of nowhere last week; it was working fine until then. After I unlatch the top, I press the button to lower the roof, but get a message stating "Unlatch Top". Top is unlatched and when I push up on it I can see it is clear from the windshield (completely unlatched). Any thoughts on what could be causing this issue and cost of repair? Thanks! Last edited by Kymaro15; 08-12-2019 at 01:27 PM. |
08-12-2019, 05:41 PM | #2 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Is the net in the trunk latched properly? Is the sensor working? Two easy things to check first.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
08-12-2019, 06:21 PM | #3 | |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
I must have locked and unlocked the top 10 times before I got the book out and read the directions. Opened the trunk and I guess I must have slid the shade back when taking the wife grocery shopping. Pulled the shad back in place and the top worked. Now before I put the top down I check the trunk.
08-12-2019, 07:00 PM | #4 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
Should be a display between the gauges with some kind of warning.
08-13-2019, 04:21 PM | #5 |
@theragtopguy - I'm aware of the cargo net and yes, it is properly secured. Not sure to which sensor you are referring. Please let me know which sensor I need to check.
@Whoomba - I do receive a "warning" message, it says: "Unlatch Top". The top is unlatched and I can push it clear of the windshield on both sides. I've had the car several years, this is the first I've had with this issue. |
08-13-2019, 05:01 PM | #6 | |
Lifetime Philly Fan
08-14-2019, 07:57 PM | #7 | |
Thread Tools | |
