04-16-2018, 07:10 PM | #1 | |
Drives: 2015 2SS Summit White Join Date: Oct 2017
Anyone know where this sound may be coming from?
Ive installed JBA high flow cats about 2 months ago, I can't remember if this sound was present on first startup because I couldn't hear anything other than the exhaust lol. Well prior to getting use to it after it warms up I always hear this "pinging" type sound, stock headers and NPP catback, just high flows. This is the best audio clip I have so far I will get a better one in the coming days, Ive gone under the car and honestly can't tell where its coming from, don't see any leaks and replaced the Cat connection gaskets which yielded no results. Per the clip I have attached it is best heard near the end when I give it some throttle. No CEL's and car runs great. One other thing I shall note, whenever I'm at a drive through and I slowly accelerate It always becomes more pronounced and sounds like you repeatedly throw cold water on a hot object. Hard to explain without a clip of that.
04-17-2018, 09:50 PM | #2 |
Drives: '18 SS 1LE Join Date: Jul 2016
from what i can hear, sounds like normal valvetrain noise
Got a better clip of the noise? |
04-17-2018, 10:48 PM | #3 |
04-18-2018, 12:45 AM | #4 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Yes sounds like normal drivetrain noise to me. Try to post a better sound clip if you can.
Mr. Clean
04-18-2018, 07:35 AM | #5 |
Drives: 2015 Summit White 2SS/RS 1LE Join Date: Nov 2014
Not the best clip, but sound like it may be the exact same thing I experienced. I did JBA cats with NPP and had what I thought was a rattle. It happened the second I lifted off the throttle and was embarrassing to drive.
I found out that it was the resonance in the stock H-pipe causing the sound. I went through a lot of effort and money figuring out the problem. I cut out the factory H pipe and installed an X pipe and it got rid of the problem. At the end of it all, I went with a Stainless Works Retro Chambered Catback, which has an X pipe and very happy with it. I bet a muffler shop would weld in an X-pipe for you for pretty cheap. |
04-18-2018, 08:28 PM | #6 | |
well work got the best of me again but I hope this clip is a little better. This is the "cold water on hot object" flapping type noise that I was referring to. This is the sound that is annoying me and embarrassing. You can hear it whenever I slowly let off the clutch as if I was driving normally. Once my buddy gets home from college in may I should be able to get it on jacks and get a better clip, but for now Im solo.
04-18-2018, 08:43 PM | #7 |
Drives: 2015 1LE Join Date: Oct 2015
well, i had a flapping noise everytime i took off and i figured out it was the flaps in the npp mufflers. they are opened at idle and when you take off they close and cause a flap noise. i pulled the fuse to keep them open and noise went away. just my experience
04-18-2018, 08:59 PM | #8 | |
04-20-2018, 09:49 AM | #9 | ||
Switch to an X pipe and you'll be good. Tried to upload a video of mine, but didn't work. PM me and I'll get you a link |
04-21-2018, 09:25 PM | #10 |
Wow I didn't think that would be the problem, but then again I checked everywhere and nothing seems to be leaking so I was going crazy. Thanks!
