01-13-2010, 08:04 PM | #1 |
Drives: Camaro 2SS/RS and 2001 Ford F250 Join Date: Oct 2009
idle too low?
Just took delivery of my camaro yesterday. Loving it and still getting used to it. One thing I noticed is when i start it up and its idling the car sort of vibrates almost like it's going to stall. It is a manual transmission. Idle is around 550. Is that about right? Is it supposed to kind of shake like that?
01-13-2010, 08:16 PM | #2 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
It's normal.
01-13-2010, 08:17 PM | #3 |
Drives: 2010 2SS CGM LS3 Join Date: Jan 2010
Feels good, doesn't it
01-13-2010, 08:42 PM | #4 |
Haha ya it is kind of cool. Almost like shes a caged animal itchin to be released. Figured it was normal but just had to check. Thanks guys.
01-13-2010, 09:04 PM | #5 |
#17,149
Love it Love it... Put it in lanch mode and see what happens.
01-13-2010, 09:13 PM | #6 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Must be a manual SS thing..... My LT auto idles around 1k when cold ....
01-13-2010, 09:21 PM | #7 |
Drives: 1991 Camaro RS Join Date: Mar 2009
If you like that, try camming it. My '99 SS shook the window panes on my house when it was idling in the garage.
2010 Camaro SS in black/beige: Sold. | '91 Camaro RS: Still the dream car!
'98 Camaro SS: Incon twin turbo. Sold | '99 Camaro SS: Heads/cam/bolt-ons. Sold. |
01-13-2010, 09:54 PM | #8 |
Drives: 2014 Sonic, 2010 Camaro SS Join Date: Jan 2009
LS3 has a split duration/lift, plus a nice lobe centerline on the camshaft. Gives it a little shake. Perferctly normal. Enjoy!
01-13-2010, 09:57 PM | #9 |
Arizona All Gens
Drives: 2SS/RS, M6, IO-Int Join Date: Jul 2007
That was the first comment my wife made when she got inside. I told her to shut up, she's used to things vibrating. Her reaction?
01-14-2010, 01:27 AM | #10 |
@MrRaZ28
01-14-2010, 02:27 AM | #11 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
I love the little shake now and then. it's not enough to notice unless you sit there for a good while. For me it's a reminder of the torque this thing possesses.
01-14-2010, 05:51 AM | #12 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
I love the shake but it's not the cam. The fuel injection system drops pulses to reduce idle emissions. Try raising the idle speed to 800 - sounds even meaner.
History Camaro's: 83, 93, 95, 98, & 10.
01-14-2010, 06:13 AM | #13 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
It's the cam. Never heard of dropping injector pulses? The same engine with a truck cam idles dead smooth. The LS3 gets a more performance oriented cam that gives it a little rumble and shake.
Put a nice exhaust system on it with an x pipe (LT's even better) , and it will really sound sweet. If it's brand spanking new, it will smooth out a hair after a few break in miles. When a motor is green it may not be the smoothest. As things like the rings seat in, the computer learns all of it's adjustments... compression across the cylinders will be more consistent and it will be a touch smoother. But this cam will always have just a slight idle shake. That's what makes it scream above 6 grand. I know Victory motorcycles drop injector pulses to make them try to sound like a Harley, but never heard of a Chevy V-8 doing that. |
01-14-2010, 07:58 AM | #14 |
Motor Head
Dodge also drops idle injector pulses at idle on the Charger and Challenger Hemis. Idle emissions are measured by volume (parts per million). So, with all cylinders pumping air then dropping random fuel pulses the bad combustion gases go down.
Similar Threads | ||||
Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 273 | 08-15-2023 04:44 PM |
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
Why does my car vibrate at low RPM and idle? | chance | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 11-11-2009 12:39 PM |
High Performance Exhaust | AntmanZ28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 94 | 08-22-2009 02:16 PM |
