05-15-2020, 07:54 PM | #1 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Engine mounts
I did my motor mounts today
I installed BMR polyurethane motor mounts Wasnt to bad !! But having long tube headers made it harder cause i had to remove them ! But all in all not bad And i did this in my driveway on my back !!! |
05-15-2020, 08:08 PM | #2 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
it's a good mod...feels much better, right?
NY5thgen.com
05-15-2020, 09:19 PM | #3 |
Those are the ones I want. My goal is to replace every bushing possible this year.
How do they feel?
05-15-2020, 10:07 PM | #4 |
Drives: 15 Camaro SS Join Date: Oct 2018
Did mine as well with the same ones when i did my build. Little bit more engine "feel" but love the mod. 1000 times better than those crummy stock mounts
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-15-2020, 10:16 PM | #5 |
I want more shake with my lope, so if that's on the menu then I'm all for it...along with the other benefits.
05-15-2020, 10:25 PM | #6 |
05-15-2020, 10:30 PM | #7 | |
Plus the out trailing arm bushing & front inner bushing I also did aluminum radius bushing inserts And last but not least Pedder XE coilcovers with the separate reservoir |
05-16-2020, 04:52 AM | #8 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I put in Detroit Speed poly mounts. My whole car shakes along with the lope of my cam. It's awesome.
More to come. |
05-16-2020, 08:47 AM | #9 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Prothane
05-16-2020, 09:43 AM | #10 |
Drives: 2015 1LE Join Date: Oct 2015
Does it make the car vibrate a lot more? That is what I read in past threads about aftermarket engine mounts.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-16-2020, 10:40 AM | #11 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
You’ll feel more of the vibrations for sure but they do soften up after some use
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-16-2020, 01:01 PM | #12 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
I have The bmr mounts with the solid Delrin inserts and it vibrates a lot but there is no movement and instant throttle response.
05-16-2020, 01:52 PM | #13 |
vibrates a lot to the point that its annoying, cant imagine that being fun to ride in
05-16-2020, 03:43 PM | #14 |
Drives: 2010 SS L99 Join Date: Sep 2018
How did you get delrin? Mine are true solid aluminum pucks, which they offer as an upgrade to the polyurethane. I had never seen them offer motor mounts with delrin "DERLIN" as some say lol, bushings. Mine are sitting on my bench waiting to get installed
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
