#Camaro6
AWE Tuning
Old 08-08-2022, 09:24 PM   #1
PMCamaro
Drives: 22 ZL1
Roll Starting M6 (dead battery)
Well I Googled Camaro6 for this and saw nothing. Case in Point--> Your battery is dead. Manual trans, You are on a hill (going down). Switch on. Can you pop the clutch in 2-3 and get started like the old days? I would try but it's put up waiting on coating.
2022 ZL1 M6
PMCamaro is offline   Reply With Quote
Old 08-08-2022, 10:07 PM   #2
donaldp
Drives: 2017 Red Hot ZL1 M6
What is your point?
donaldp is offline   Reply With Quote
Old 08-09-2022, 05:22 AM   #3
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
In a word, no. Electronics need to initiate before the engine can run. No power, no start, rolling or not.
Nothing like an SS is offline   Reply With Quote
Old 08-09-2022, 06:44 AM   #4
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I agree. While I've never tried it on mine to be 100% certain - I believe the good old days are over for this. In the age of push button start and drive by wire throttle I just can't see this working.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 08-09-2022, 07:10 AM   #5
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
If you could get the engine turn and produce "just enough" power to activate the necessary pieces... maybe... just maybe... But, it would have to be a decent hill and you'd have to leave the clutch out for a bit of distance to get it to turn.
Even then... Who knows if it would be able to actually RUN. I've had my car misfire and refuse to actually run properly after sitting for a few weeks. It has taken as many as three start attempts to get it to catch correctly and run without stalling. And that was with a brand new battery.
ember1205 is offline   Reply With Quote
Old 08-09-2022, 07:10 AM   #6
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
There are a few vigorous discussions online on this topic.
The short answer is "maybe."
You need to be at the top of a long hill or be pushed for a while. You need alternator to produce adequate current to get things going (ECM, fuel pump, etc.). It may not be possible with a completely flat or damaged battery, as a weak battery which may not be able to crank the car can still power other things. You also need battery voltage at the alternator stator coils or alternator does nothing. Generators have magnets, alternators require current in the stator to provide the magnetic field.
As an aside, the repair manual for our car refers to the alternator as a generator, which is an horrendous oversight/error.
ctrlz is offline   Reply With Quote
Old 08-09-2022, 10:47 AM   #7
Osbornsm
Drives: 2018 SS 1LE
I used to do it to my 370z all the time.
Bump started like a champ.
I don't see why the Camaro would be different. Just needs more hill due to increased mass and engine drag.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is online now   Reply With Quote
Old 08-09-2022, 10:59 AM   #8
ctrlz
I don't know Alabama. Do they have hills big enough to try this?
I'm kinda hoping this all theoretical talk, and OP would call AAA for a jump.
With all the electronics in modern cars, there tend to be warning signs when a battery is past its prime. The only people I know who have been caught out with a dead battery are the types that ignore all the signs and hope for the best. So, if you're that type, always park on top of a steep hill.
Old 08-09-2022, 11:05 AM   #9
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
What about the "foot on the brake to start" issue?
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 08-09-2022, 11:09 AM   #10
Allez
Allez's Avatar
Drives: 2016 Camaro 2SS
Of course if this doesn't work you're gathering speed going downhill with no power brakes and no power steering. . .
Allez is offline   Reply With Quote
Old 08-09-2022, 11:10 AM   #11
ember1205
Hot Camaro
ember1205's Avatar
My guess is that's only required to allow the starter to engage.
The bigger issue would seem to be that you'd need to get the car rolling, pop the clutch, then hit the 'start' button to allow everything to power up, then "hope" that there's enough juice to allow fuel pressure and spark...
Old 08-09-2022, 11:11 AM   #12
ember1205
Hot Camaro
ember1205's Avatar
But -with- engine braking. Toss up?
Old 08-09-2022, 11:32 AM   #13
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
that's just for the auto driver nanny.
Old 08-09-2022, 11:45 AM   #14
Nothing like an SS
Faster!!!
No power, the fuel pump will not even prime. No power to ECM, etc. Debate all you like, it can't be done, engine will not fire, and you will not have much in the way of brakes or steering while attempting, so good luck at the bottom of that very steep hill!
If you really want to try it, good luck!
