Old 10-23-2018, 06:51 PM   #1
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
115K on Original pads
Yep you heard it right 115k. 110k is highway driving though so I am sure that helped. Pads are starting to wear a bit, and an end of the month inspection is needed. Instead of having my station do them with an inspection, I figured this would be something I could do pretty easily. Rotors are no cut into, so no replacement there. Basically just pads and thats it. Any recommendations for pads, and how I could get another 115k miles on them?
kostnkost is offline   Reply With Quote
Old 10-25-2018, 11:20 PM   #2
pinoyplaya
Drives: '13 SS RS
wow impressive. Mine is just less than 44k and about to replace em. Really close to the wear clips.
2013 Camaro SS RS
pinoyplaya is offline   Reply With Quote
Old 10-26-2018, 05:14 AM   #3
Niceun
Niceun's Avatar
Drives: 2012 45th edition RS 2LT
I have 103K on my 2012 and plan on doing the job this weekend. AC Delco at Oreilly's is $239!!!!
Niceun is offline   Reply With Quote
Old 10-26-2018, 08:14 AM   #4
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
A local shop here charges $450 to do rear rotors, pads, and 1 caliper....even when you provide the parts!!!!! What about that job costs that much?!
But anyway, smart move doing it yourself, OP.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-26-2018, 08:16 AM   #5
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
I'd go with PowerStop Pads, but I'd replace the rotors as well.
ZEN357 is offline   Reply With Quote
Old 10-26-2018, 01:29 PM   #6
kostnkost
kostnkost's Avatar
You think this is a must with that many miles on my car, and the original pads lasting this long?
Old 10-28-2018, 10:18 AM   #7
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
With that many miles on everything it'd still be worth checking the rotors for thickness with a micrometer. If that measurement on any rotor is at or below the minimum "machine to" thickness, it's time for new rotors at least on that axle.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 10-28-2018, 02:55 PM   #8
silverstorm
silverstorm's Avatar
Drives: 2014 Camaro 2LS
Where in TN do you live because a shop I went to charged a little over $200 to do all 4 rotors and pads, providing my own parts.
silverstorm is offline   Reply With Quote
Old 10-28-2018, 03:14 PM   #9
pinoyplaya
Drives: '13 SS RS
The cost to turn the rotors is almost equivalent to just ordering a new set of rotors. Might as well order a new set. Look at R1 Carbon Rotors.
2013 Camaro SS RS
Old 10-28-2018, 03:56 PM   #10
silverstorm
I replaced my brakes and rotors a month ago. Got my set from Brake Performance for $370 I believe. My car only had 70K on it but I went ahead and replaced everything.
Old 03-13-2019, 05:21 PM   #11
kostnkost
kostnkost's Avatar
Just jinxed myself..... Brakes are squealing and grinding pretty bad. Looks like I will invest in rotors and brakes.
On a scale of 1 to 10, how difficult a task is this? I am pretty handy, and have done a few things with the car including a cold air intake, catch can and throttle body.
Also if someone can point me in the right direction for purchasing new pads and rotors. I saw someone mention brake performance.com so far.
Any advice is greatly appreciated!
Old 03-13-2019, 06:49 PM   #12
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
It’s a pretty easy job. Very straightforward. I believe there are some diy threads on here. I’m running powerstop pads and rotors and they’re very nice and fairly priced. You can get them on amazon.
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 03-13-2019, 10:25 PM   #13
silverstorm
Not a hard job at all, you can get all 4 corners done in 2 hours or less even if you take your time. 1A Auto on youtube has a really good video on changing the brakes and rotors for a V6 Camaro
Front: https://youtu.be/GlDiHibH1-Y
Rear: https://youtu.be/YDuCnMM5E8o
I'd recommend powerstop or brake performance for a full kit
Old 03-13-2019, 10:33 PM   #14
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Holy jeez. That's a lot of easy on the brakes miles.
I'd stick with OEM parts since they lasted you that long.
The brake job is easy, but you also must flush out the old brake fluid. That should be done annually.
Carefully clean the pistons with brake clean before pushing them in. I've seen a lot of lazy brake jobs not taking that step, but it can lead to issues down the road. Make sure the seals are good - if not go ahead and get a caliper/piston rebuild kit. Brakes are too important to take shortcuts.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
