#Camaro6
Old 07-16-2018, 01:29 PM   #1
thelittlelim
Drives: 50th SS
less than 10k mi and tires are dead
Is that normal?
17 SS running with original tires from dealership. I am extremely conservative with the gas pedal. I may have taken some decent turns before but it just doesn't seem right that the wear on my tires have taken its toll.
not even at 10k mi and tire store said they're almost no longer legal
thelittlelim is offline   Reply With Quote
Old 07-16-2018, 01:43 PM   #2
Sev
Sev's Avatar
Drives: 2016 2SS / 2004 Tacoma
I've got over 15k on my SS tires, with some aggressive driving mixed in, no problems with treadwear. Did you buy your car used?
2SS, Manual, Blue Velvet Metallic, Medium Ash Grey, Black Wheels, MRC, NPP, Black Bowties, Black GM Tail Lights, Oracle LED side markers.
"I'm going to drink you pretty, beautiful toad"
Sev is offline   Reply With Quote
Old 07-16-2018, 01:44 PM   #3
crosive
Drives: 18 zl1
I'd say you are on the lower end of the spectrum, but I have seen worse, and better.
From what I've read, 15k seems to be typical, with some seeing as much as 20-30k. I've also seen some people report 5k-8k.
It depends on the driver and how much their throttle plate smells like feet.
crosive is offline   Reply With Quote
Old 07-16-2018, 01:57 PM   #4
gpskinzhut
gpskinzhut's Avatar
Drives: 2017 ZL1 A10
Mine were getting slippery by 9.5k or so. Not a single burnout but a few trips on the tail of the dragon and the winding East TN roads did a number on them in short order. Replaced at a little over 10.
2017 ZL1 A10
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is online now   Reply With Quote
Old 07-16-2018, 02:08 PM   #5
thelittlelim
Drives: 50th SS
brand spankin new :(
Old 07-16-2018, 02:10 PM   #6
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
I had Pirelli P Zero on my 14 GT. They wore out within 12k, and I sent a letter to Pirelli.
They basically told me to pound sand. Apparently, that's the lifespan of "performance" tires, just about 10-15k is what they made mention to.
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built!
TheRedhead is offline   Reply With Quote
Old 07-16-2018, 02:18 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Poor alignment can lead to accelerated tire wear.. as can soft tire compounds.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 07-16-2018, 02:57 PM   #8
redcoats1976
which is weird,mine have 34,000 on them but will be needing new tires by fall i think.i am going to try some firestone firehawks next.
Old 07-16-2018, 02:58 PM   #9
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
You have an LT though...you will get more mileage than the SS guys.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 07-16-2018, 04:01 PM   #10
LuvMI
Lovin the growl...
LuvMI's Avatar
Drives: 2018 2SS
Get a second opinion on the tread wear.
2018 2SS: Garnet Red, NPP, Kalahari interior, sky lid.
LuvMI is offline   Reply With Quote
Old 07-16-2018, 08:05 PM   #11
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
2016 LT here bought in April 2016 and at 43k miles and I think I'm still good on treadwear. Haven't measured but looks like a solid 30-40% except on the edges. I'm hoping to make them last till the end of this year.
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 07-16-2018, 08:17 PM   #12
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
How much life you get out of a set of tires depends on a number of factors, some of which have been pointed out.
One thing that's less obvious is the quality of the rubber used when the tires were made. Rubber can vary significantly in quality from batch to batch, so while the design of the tire and grade of rubber can significantly affect tread life, the batch of rubber used throws in a big wild card.
I don't think tires on a new car come with any sort of warranty, but virtually all new aftermarket tires do regardless of whether you purchase a separate road hazard warranty (which is worthless as far as tread life goes anyway). This typically works on a pro-rated basis. So let's say the tires are rated at 30K miles and at 15K the tread depth is 3/32. The manufacturer will pro-rate them at 50% which means you get that much credit towards a new set of tires. Many of the manufacturers' warranties work that way, but you need to verify this at the time of purchase.
dfwcowboy is offline   Reply With Quote
Old 07-16-2018, 08:22 PM   #13
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
14k Miles right now, I’d say I have around 50% tread left. Plenty of aggressive driving mixed in.
70chevelleSS is offline   Reply With Quote
Old 07-16-2018, 08:36 PM   #14
Chazzz
Chazzz's Avatar
Drives: 2018 1LT RS V6 A8 Convertible
Honestly the staggered summer tires on the SS is the main reason I am on my 3rd LT. Living in the northeast and knowing the summer tires are not made to run under 40 degrees, along with the fact that these expensive tires can't be rotated front to rear and the softer rubber has a much shorter average life span. In the past while living in Florida I left my summer performance tires on year round, and just the very few cold days we had there cracked the tread making the tires unsafe. I use my cars as daily drivers so that plays a huge role in my decision also...
Chazzz is offline   Reply With Quote
