11-29-2019, 06:40 PM | #1 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Oil Filter Wrench
For you guys with headers, what oil filter wrench are you using? I'm going to be needing a new one. The one I have barely fits with the headers and is probably about to break. I use Wix Filters too if that makes a difference. Just curious!
11-29-2019, 06:43 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I just use this
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
11-29-2019, 06:48 PM | #3 |
I use one of those crappy metal ones that fit over the end of the filter that you turn with a socket wrench. I don't suggest you use them because they are garbage and eventually stretch, just spinning on the filter.
But since you asked.
11-29-2019, 07:17 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Imo... if you need a wrench to remove it then you put it on too tight...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
11-29-2019, 07:40 PM | #5 | |
376 cubic inches of fun
If' you're deforming the wrench, you are over-torquing. |
11-29-2019, 08:24 PM | #6 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I use the K&N filter with the hex head on the end.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
11-29-2019, 08:37 PM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Something like this.
11-29-2019, 09:14 PM | #8 |
Drives: ABM #93 Join Date: Oct 2018
I use a screw driver... no joke. I use the screw driver and a hammer to gently knock a hole in bottom of the side of the filter and let it drain. Once it drains just slide the screw driver in the hole and you can leverage the filter loose. I started doing it this way because the dealer I bought the car from spilled oil all over the exhaust when they changed the oil. Took about 2500 miles for the smell to go away completely. It would come and go depending on how spirited my driving was. I read several threads similar to my issue on here. I’ve changed the oil 2 times now on my own and no oil smell at all.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. Last edited by Aqua Blue RS/SS; 11-29-2019 at 10:03 PM. |
11-29-2019, 09:23 PM | #9 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
If I installed it in the first place, I usually don't have a problem taking it off just with my hands if I have good leverage. I think applying a light coat of oil on the gasket before you put it on helps with this.
11-29-2019, 09:44 PM | #10 | |
I have always been paranoid about the filter eventually vibrating loose. Although it has never happened to me and I don't know anyone that it has happened to. But I am not going apesh*t on it. Just hand tightened...and then probably snugged a little more.
11-30-2019, 10:12 AM | #11 | |||||
Thanks for the suggestions guys! |
11-30-2019, 10:26 AM | #12 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I use one like that. I always put some oil on the rubber seal.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
11-30-2019, 11:09 AM | #13 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
11-30-2019, 02:41 PM | #14 |
That is exactly what I use, but I never go past the recommended amount of turning from gasket contact to fully tight.
While some filters have a fine enough thread to call for 1 full turn, the PF48 is coarser and so the requirement is 3/4 turn. For me, it's hard to do this reliably by hand if I'm lying on my back with the car up on ramps. I can either see the filter or be in a position to turn the filter, but not both at the same time. So I use the cap wrench. I align the ratchet handle with a reference on the chassis and turn it 270 degree. That is snug but never a problem getting the filter off. I can't imagine deforming one of these cap wrenches. I have three sizes for various cars, and they are all at least 25 years old. |
