07-14-2019, 06:20 PM | #1 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Pics of What Makes Z28 Suspension Different
I read the parts list and what is supposed to be different, but while I had one apart, I figured I would take some picks.
I didn't show the shocks and springs or the insert on the radius arm since there are already in other threads. I don't see much difference in the rear LCAs other than the addition of a position sensor on each side and the little ball it connects to. The cradle bushings have no voids They use this yellow, solid trailing arm bushing. The rear upper control arm bushing is solid and very stiff. It's been a while since I replaced my toe rods, but I don't remember them having this type of joint at the end.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
07-15-2019, 05:43 AM | #2 |
Drives: 2015 z28 Black w/ac #645 Join Date: Jan 2017
Here's the rest of what separates a Z/28 from other camaro's minus the CCB's. Saw this whole package for sale i think in Germany quite awhile back .
07-16-2019, 06:32 AM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
JPSS used to sell the rear knuckles for like 225 would be nice to find a set of them now days, one of the last things I need to comeplete rear suspension.
Orange Krush II
07-16-2019, 09:49 AM | #4 | |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
https://www.gmpartsdirect.com/oem-pa...uckle-23262766 |
