Old 11-10-2018, 04:38 PM   #1
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
6L90E swap
Im in the process of swapping a 6l90e into my 2010 SS. I noticed that the tranny casing is a lil longer. My question to those of you that did this already; did u you have the drive shaft shop make a custom one or will a stock zl1 drive shaft for auto will bolt directly up. Im using a zl1 diff as well. Thanks in advance for your assistance!
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 11-10-2018, 10:44 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
If your doing the tranny and rear at the same time then yes a ZL1 shaft will work.
HOJO is offline   Reply With Quote
Old 11-11-2018, 01:01 PM   #3
1985airborne
One Slow Automatic
Thank u!
Old 01-05-2019, 08:17 PM   #4
jimarvis
Drives: 2012 camaro ss
I want to do the same swap.How are the electronics swap?
jimarvis is offline   Reply With Quote
Old 01-06-2019, 04:08 PM   #5
Roader
Drives: Camaro
I spoke with DSS about this back when I was looking to do a 6L90 swap. I’d highly recommend measuring and seeing what you need. Zl1 and SS diff are different so not sure that a zl1 Ds will work
Roader is offline   Reply With Quote
Old 01-21-2019, 08:46 PM   #6
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
How did the swap go?
What did it cost total parts wise?
hpw did you get the TCM to work with the SS ECU?
Did the stock ZL1 Drive shaft fit with SS dif?
I'm torn between a 6L90 swap or a rebuilt Circle D Trans Level 3 800hp....
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 01-21-2019, 09:18 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
If I remember correctly, the 6L90 will need the TCM from the 6L80. I’m going with a 6L80 rebuild from GPI...
-Don
747 RWHP 794 RWTQ
Old 02-16-2019, 03:43 AM   #8
John_C
LSx FTW!!!
John_C's Avatar
Thumbs up
-Don
A Tim King Stage II 6L90 is good to 1,000hp.
That's what I went with...
HP Tuners VCM Suite
