Old 07-09-2013, 11:46 AM   #1
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
Steering Wheel Locked
I'm trying to install my ZL1 grill this morning, and I have the wheels all the way to the right to get access to the wheel well, and I go to turn the wheel to get into the other side and the wheel is locked. I can't get to the key to turn a cm and the wheel is just locked solid. I can't get it to move at all to try and jiggle it loose with the key. Help?
Austin45 is offline   Reply With Quote
Old 07-09-2013, 11:49 AM   #2
2012-1822
2012-1822's Avatar
Drives: Black ZL1
I don't know. But there has been a time or two when mine was turned all the way and it was a booger to get it to unlock. I just had to give it a heave to get the key to turn. I know you've tried that already, maybe an extra set of hands to pull on the wheel while the key gets turned maybe.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 07-09-2013, 11:50 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Really? You need to pull it in the same direction it currently is in while turning the key.
FSP tuned: 377/389
Old 07-09-2013, 11:51 AM   #4
VENOM XLI
Drives: 2010 Satin Pearl White 2SS
Your V6 Camaro is telling you it doesn't want a ZL1 grille
VENOM XLI is offline   Reply With Quote
Old 07-09-2013, 11:52 AM   #5
MR.Sarge
MR.Sarge's Avatar
Drives: 2015 2SS/RS 1LE
Usually if the steering wheel locks and key wont turn, from my experience, turning the steering wheel as far as you can possible with your strength in the same direction you already turned the wheel while also turning key should start to crank the key and start car for you to unlock the steering wheel.
MR.Sarge is offline   Reply With Quote
Old 07-09-2013, 11:52 AM   #6
Goober
Drives: Camaro
really?
Goober is offline   Reply With Quote
Old 07-09-2013, 11:54 AM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Originally Posted by nyrfan View Post
You need to try and pull it in the same direction it currently is in while trying to turn the key.
This
You need to relieve the tension on the lock mechanism by turning the wheel into the turn slightly further. While you are holding the steering wheel, then turn the key.
Best regards,
Tyler
888-308-6007
Old 07-09-2013, 12:08 PM   #8
Austin45
The Logistician
Austin45's Avatar
Thanks, got it... finally.
Old 07-09-2013, 12:11 PM   #9
MCSarge
USMC 1980-1990
MCSarge's Avatar
Drives: 2010 Camaro 2SS/RS
I accidently locked the keys in the car with the motor running. It's been three days and the wife is trapped inside and really pissed, what should I do.
USMC 1980-1990
My other toys are Harleys
MCSarge is offline   Reply With Quote
Old 07-09-2013, 12:15 PM   #10
mcbeth15
mcbeth15's Avatar
Drives: '11 RS 2LT IBM
Buy a new car!
mcbeth15 is offline   Reply With Quote
Old 07-09-2013, 12:15 PM   #11
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
get a new wife. :lmao
-John S.
Old 07-09-2013, 12:16 PM   #12
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
Walk away!
Mind controlled by Cerebro
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 07-09-2013, 12:19 PM   #13
DefianceDan
VroomVroom
DefianceDan's Avatar
Drives: 2017 50th 2SS
Isn't it SOP to remove the tires and walk away?
2017 H50 2SS MX8 F55 NPP CF5 RN2
DefianceDan is offline   Reply With Quote
Old 07-09-2013, 12:27 PM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
LOL, reminds me of why dogs are better friends than wives. If you're not sure, lock both your dog and your wife in the trunk. Comes back and open it 3 hours later. Which one is happy to see you?
