02-28-2021, 09:38 PM | #1 |
Dynawide100
Drives: 14 Camaro 2SS,L99, CAI intake, kook Join Date: Feb 2016
Engine detonation
I have a 2014 Camaro 2SS 6.2l L99 and getting engine detonations when under a load. Only have 91 octane available and have changed gas companies to see if it was a gas problem however no change. I'm running longtube headers w/ high pass cats and cold air intake. Wondering what the default engine timing is to verify if mine is off. Running a canned tune from my SCT X4 tuner. Any help would be of great assistance. TIA
03-01-2021, 06:09 AM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Who did your tune? I would start there and contact that person.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
03-01-2021, 06:19 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I had issues with a bunch of knock retard using canned tunes. A real dyno tune is worth the investment.
03-01-2021, 08:07 AM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
[QUOTE=larry_g;10963975]I had issues with a bunch of knock retard using canned tunes. A real dyno tune is worth the investment.
Sent from my Pixel 5 using Tapatalk[/QUOT
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-01-2021, 02:19 PM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
canned tune is likely the issue. At the very least have dynosteve or Jannetty racing provide you a real tune, if there is an issue they will ask you to datalog so they can see what is going on and fiz the issue if it is within the tune.
Also make sure your headers aren't too close to the frame. False knock from them hitting the frame under hard accel or hitting a bump will cause knock retard issues.
03-02-2021, 01:09 AM | #6 |
Dynawide100
Thank you all for your input and I'll see what my next step is going to be. Had issues with the headers hitting the frame before, not sure if it's doing it again. I appreciate everyone's assistance.
