JUICEDMOTORSPORTS
Old 06-17-2019, 07:13 PM   #1
V8only
Drives: 2012 camaro 45th 2ss/rs Centri SC
Supercharged 12ss not Any faster then stock
Before I get all the jokes about being slow, just hoping I can get some solid advice.
I'm running a Kraftwerks centrifugal Supercharger on my otherwise completely stock 12ss M6 Camaro.
Tuned by a very reputable local shop. Put down 460 to the wheels on a mustang Dyno at 4.5 psi. Supposedly it'll do 530 on a dynojet but that's besides the point.
I've talked with others with my exact same combo and 11.8s in the 1/4 can be expected with optimal circumstances.
I live in California where it's hot and the gas is crap.
Last bit of info. Since I've had the car and BEFORE the blower Install, it surges and bucks when cold. Still does it. Second it warms up though that goes away. No codes. Tuner didn't see any missing under boost.
I've put 1-2k miles on it over the last 6 months and have had the chance to run a number of cars.
I'm having trouble chasing down 13 second cars. Nevermind the launch because it's a stick, but even after launch it just doesn't gain. Today I ran a 15-20 year old Mercedes e550. A 13.10 car and I ran dead even, or honestly he got me by a car, but wasn't really pulling on me.
This is my first blower car so I'm new
-Crap California gas?
-stock temps to high and causing computer to pull timing?
I'm thinking my computer just me doing something to pull timing or power out of it, but I'm at a loss here
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger
-2003 Avalanche z71-6" on 35's. DD 290k miles
-66 mustang fuel injected resto-mod
V8only is offline   Reply With Quote
Old 06-17-2019, 09:52 PM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
Their website says with the 85mm pulley it makes 600hp at 7psi. Im guessing thats a crank rating, so at 4psi, you’re right where you should be. But yea, thats cam/bolt on power territory. Turn it up and get headers if u can.
TMS Dart 427 FED M311s, TMS cam, ESS Tuning G3X Blower, DSX Tuning Triples and FF, FIC1300, Mcleod RXT 1200HD, JRE Tuned 935/856 16.5psi... G4 coming soon.
eLeSthree is offline   Reply With Quote
Old 06-17-2019, 10:20 PM   #3
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
You need more boost and/or mods to go faster.
You also definitely need a re-tune if your having all those issues.
You can't expect huge gains from a completely stock car on 4.5lbs boost.
2010 CGM Camaro 2SS RS A6 760rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 2 CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 06-18-2019, 10:07 AM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Call Leading Edge Performance in Las Vegas and make a road trip to get your car tuned right.
Lots of bolt on stuff
Bests in each category
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 06-18-2019, 11:46 AM   #5
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
Centrifugal Superchargers don't have the torx for a fast start like a roots S/C does.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 06-19-2019, 03:28 PM   #6
V8only
thanks all. I'm going to have the tuner look at it. I realize it's just a baby blower, but christ, I can't seem to pass anything that I think that I should be able to. I suppose running my brothers bone stock 14 ss would show me if I'm ahead of the game or if something is truly wrong.
There is no damned torque that's for sure, and by the time it starts making power, I have to shift. Perhaps what I need is to sell this off for a roots supercharger, but coming up with the extra cash won't be fun.
I got a KILLER deal on this unit, so i'm not really too upset, but christ it just isn't enough
Jeremy
Old 06-19-2019, 05:25 PM   #7
stevieturbo
Drives: Volvo
Sadly the Rotrex is a very poor choice for such a large engine. They're just too damn small.
Pulleying for more boost may be an option, as would ensuring all tuning aspects are good. But ultimately that kit is just poor.
stevieturbo is offline   Reply With Quote
Old 06-20-2019, 01:19 AM   #8
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Spin the blower as fast as you can (smallest pulley)
Get s new tuner. If it’s bucking one of the tables has something quirky going on in one of the temperature ranges.
UNRIVALED SS is offline   Reply With Quote
Old 06-20-2019, 08:36 AM   #9
JANNETTYRACING
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I can help you https://www.camaro5.com/forums/showt...ght=kraftwerks
www.jannettyracing.com
Celebrating 34 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 06-20-2019, 01:16 PM   #10
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
E85 and smallest pulley is what you need. I had that kit with 75mm and made 630 whp with LT headers, NA cam and e85 on a LS3. You can even get a 70mm pulley
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 06-20-2019, 01:18 PM   #11
JANNETTYRACING
The 70 mm puts the supercharger way past the safe operating range.
Ted.
Old 06-20-2019, 01:27 PM   #12
V8only
Originally Posted by JANNETTYRACING View Post
I'm local to them, and had it installed by them. It has been super reliable, however I have NO experience to go off of. I dyno'd 460 on a mustang dyno, so that's a bit conservative, but I just don't seem to make good power. I don't pull on cars that I should have no issues pulling on. Because of my lack of experience, I have no clue if my computer is pulling timing or something, or if this kit is just that slow. My brother has a 14 SS bone stock, and I'm going to try and run him Friday night, just so I can see how I do on a comparative car without the blower. I'm at a loss and pretty frustrated, but getting beat out the other day by a 99 e550 was the last straw. I don't know if he was modded, but I doubt other then the exhaust he had. Those are only 13.10 cars.
I'm going to look into the pulley for sure, but I still have the stock fuel pump. Part of the problem I suspect is the HORRIBLE california gas. I've been thinking of running e85 and the 70mm pulley, but not sure what to do about a fuel pump...I would like to run the zl1 pump because it's cheap, but not sure if it can handle e85 and a 70mm pulley and eventually long tubes.
this is what is a big red flag for me, but it's been bucking since I bought the car 3 years ago bone stock. It only does it when cold.. Second it warms up it's not noticeable. The tuner is very reputable, and tuned it as he saw no missing under boost. So far I have been unable to diagnose why it's doing th is, and am really wondering if it's effecting it when warm, and the computer is pulling timing or something. I have a handheld diablosport and can pull live data from it, but have no clue how to read that.
Jeremy
Old 06-20-2019, 02:58 PM   #13
760bowtie
760bowtie's Avatar
I had the zl1 pump and ADM FPCM on mine when I hit those numbers.
Old 06-21-2019, 11:49 PM   #14
V8only
Ok all I got to run against my brothers 2014 SS Which is BONE STOCK. He even had a passenger. We went from a roll in first to avoid driver error launching.
We were neck and neck. He was pulling on me a little. This is bad news because I'm Supercharged and I'm SLOWER then a factory stock car.
So IDK what the hell is going on but I'm running slower then hell.
Jeremy
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
