Old 09-15-2019, 10:05 PM   #1
BigJ
BigJ's Avatar
Drives: Red 2013 Camaro SS, Black 1980 Z28
BBK Throttle Body??
Will the BBK 95 MM throttle body yield a horsepower increase? With a tune? Thinking about getting one!
BigJ is offline   Reply With Quote
Old 09-15-2019, 10:16 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
LS3 intake manifold opening is 92mm. So the 95mm throttle body will not increase hp for the cost of it.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 09-15-2019, 11:42 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS LS3 Swapped A6
Same benefit of most the other ported throttle bodies. Increased throttle response and maybe the tiniest power increase, probably immeasurable.
It is one of those mods that you do to increase the effects of another mod, such as CAI, headers, etc. It all adds up.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7º overlap) on CamMotion 8620 core, Melling HV 10296 oil pump, CHE trunnion upgrade, stock heads milled .015, TSP longtube headers (Catless), FM Outlaw axle back/X-Pipe, Stage 2 PTB, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º stat - Megan Racing adjustable coilovers, Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
Old 09-16-2019, 11:52 AM   #4
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
so, question - i have CAI and headers, with hi-flo cats, would adding a throttle body add anything worth the price. i know that is a subjective question but just wanting your opionion. i was think about adding one as well but hesitant on if it is worthy. oh, i am dyno tuned as well
MODS: VARARAM CAI, Catch Can, 1 LE front/rear sway bars, engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 09-16-2019, 12:09 PM   #5
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot (G7C)
Adding a ported throttle body adds very little hp if any. The real reason for getting them is better flow, and getting rid of lag in the throttle. Same thing with porting the intake manifold, no gain just better flow.
H&R 1.8/1.7” drop, Overkill 80mm, intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional)
15RS2NV is offline   Reply With Quote
Old 09-16-2019, 12:27 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Not really and if you haven't yet, don't buy the BBK throttle body. MANY on the forums have had issues with the plate sticking. I'd recommend either a Bo White ported throttle body (which I run) or a VMax ported throttle body. While you don't gain anything more than 1-2rwhp what you get is better throttle response which feels like more power.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 09-16-2019, 03:39 PM   #7
BigJ
BigJ's Avatar
Thank you guys for the info!! Dont think I'll waste my money on one right now!!
Old 09-16-2019, 06:01 PM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
No HP gains on the dyno. Road racers benefit from throttle response, that's about it.
Greenhornet2 is offline   Reply With Quote
Old 09-16-2019, 08:26 PM   #9
BigJ
BigJ's Avatar
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
