01-31-2019, 08:02 AM | #1 |
Drives: 2017 Camaro SS Convertible Join Date: Feb 2018
2017 Camaro SS humming noise
2017 Camaro SS Humming noise
I need some help. A humming noise has been overwhelming on my car rolling at 65 mph on deceleration. The dealer says its uneven tire wear. At this point I have already ruled that out because when I turned it on this morning I was disturbed by this loud humming noise that happens sometimes when I'm driving as well. Dealer cant figure out what it is. Does anyone have any idea on this? This noise is very annoying!! |
01-31-2019, 08:26 AM | #2 |
Drives: 18 zl1 Join Date: Aug 2017
can you be a little more specific as to the origin? speed related? rpm related? constant hum or variable? do you have the bose stereo?
01-31-2019, 08:38 AM | #3 |
Humming noise happens every now and then on cold startup then while driving 65 mph on deceleration. No Bose stereo on this 1SS
01-31-2019, 08:39 AM | #4 |
Usually hear it on the right side of the car but as it gets louder its difficult to hear where it's coming from...
01-31-2019, 09:18 AM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
When you say deceleration, do you mean completely off the gas and letting it coast to slow down? If the noise stops when you're off the gas it may be the rear diff. Tires can easily make noise, but an alignment that's off can also cause the tires to make noise. Have you had the alignment checked? I'd have it checked to rule it out.
01-31-2019, 09:22 AM | #6 |
What does my alignment have to do with the noise happening at startup?
01-31-2019, 09:28 AM | #7 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
Automatic or manual transmission? This sounds like transmission noise.
01-31-2019, 09:30 AM | #8 |
Automatic. First 2 times they just flushed the transmission and blamed it on the tire wear,but when the noise happens at startup thats throws their opinion out the window. They also said it might be the torque converter. I like yes,but in park???
01-31-2019, 09:34 AM | #9 |
Does the noise change when you shift out of park into drive or reverse?
Also, since it hums while in park, does the sound change when you open the hood? I suspect that if any belt-driven components (e.g. alternator) were the problem it would be louder with the hood up. |
01-31-2019, 09:48 AM | #10 |
It hums in park but not all the time. This morning was over whelmj g though..lol when I'm at 65 mph(usually when it hums) then shift to neutral it goes away
01-31-2019, 09:56 AM | #11 |
01-31-2019, 09:56 AM | #12 |
Drives: Chevy Blazer Join Date: Sep 2009
The torque converter is always moving, no matter what gear you're in... Or at least it used to, lol.
It does sound like the torque converter, if neutral made the noise stop (sudden reduction in noise), but could also be a loose/worn mount, or something in the serpentine system... But I'm leaning towards transmission. Can you try and record the hum? Sent from my SM-G965W using Tapatalk |
01-31-2019, 11:02 AM | #13 |
01-31-2019, 11:41 AM | #14 |
Drives: 2018 Camaro 2SS Hyper Blue Join Date: Apr 2018
video?
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK | |
